McMillan Calculator
How accurate are the predicted times?
Lets say entering 5K and looking at 1/2 and full marry.
Seem to work pretty well for my girlfriend (144lbs)
But for me, at 170lbs, my 5k time predicts 1/2 and full marry times that I cannot do.
Which makes sense really.
I think it says on there that the times are less accurate when you are using a short distance (5k) to predict a long distance (1/2 or full marathon).
works fairly well for me when i put in a 1/2 mary time. might estimate a 5k time a little quicker then i seem to be able to pull off.
close though.
I would say pretty accurate, big caveat is putting in the work required for the distance. After a year of always running 10km races after doing a 100k plus bike ride I did one fresh in October and ran 36:40,put in a little bit more of a run focus from that point on an ran 1:21:45 in a Half 5 weeks later (McMillan had me running 1:21:53)
So all in all it is a good guide for what pace you should aim for in race planning. If you enter a 5k time I would assume that in the lead up to your half you would be running a 10k or 10 miler, so this should give you a guide on how your training is going. Likewise I would expect you would run a half prior to a full and this should give you a good guide.
I also try and use the guideline paces for training from the calender as they match very closely what I got from doing V02 max and lactate testing. For reference I am at about 175 pounds so not sure the weight has a huge influence. Another technique for predicting a marathon time is to do Yasso’s 800’s. See this link for details, my training partner swears by this for predicting his marathon times http://www.runnersworld.com/article/0,5033,s6-51-0-0-624,00.html
Running an 8km tomorrow so McMillan says I should run around 29 min…so we will see if this right (Race plan is to give it so could go well or could bomb and go slower)
It works GREAT for me with the exception of the 5K time- i am much better at longer distnaces, dont have much top end speed- so the 5K time is faster than i can do, but it basically perfectly predicts my half mary, mary, and my within tri- half mary and mary. Im actually really sprursied at how good it is.
I will let you know after this Sunday! I am running the Phoenix Rock N Roll Marathon this weekend and I was curious myself to see how accurate the marathon time will be. I have had the same experience as others in here, that my 5K times seem a bit out of my range.
