For the last year, my mean TSS has been ~125, with normal weekly totals of 450-600. 14 rides were above 200. In the last month, I’ve ridden 3 that are ~300. I haven’t yet detected a massive recovery problem from them (knock wood). And I’m pretty sure I have my FT about right, so I’m not overestimating the effort of the rides.
I’m curious to hear from the fellow experienced data geeks about what TSS level is the maximum one can dish out before experiencing severe declining marginal utility (or even negative).
If you don’t mind, how much and what type of running are you doing on top of this amount of biking? The pure biking guys seem to thrive on TSS scores that average up to and a bit over an average of 700TSS/week with a good bit of variability. I have to think that running 40 miles per week or even 25 quality miles per week has to make this level a real overload for triathletes. Does the IF of your rides run IM level and higher or are you spending huge hours noodling around this time of year?
The correct metric is your TSS/day average, not your average TSS. Dedicated athletes should be able to handle more than 100 TSS/day with the proper build, etc. At 450 to 600 TSS per week you should have quite up bit of headroom before you hit your ceiling.
Best Regards,
Hugh
Zero running for last 2 months (hamstring problem that refuses to improve). My IFs center around .85. My rides are either 1.5 hours of hard work (IF .90) or 3-4 hours of Z2-3 (IF .75-.85).
But… my question is what max TSS is sensible for a single ride (I don’t think I made that clear in my first post). Obviously, I can’t do a 700 TSS ride and be done with it for the week. Or can I?..
I have been told not to go over 300 TSS in a day, however I had some rides last summer training for Kona when I had TSS scores in the 400’s. I think I maxed out at a 467 one day. A few easy training days after that and I was good to go.
I guess it depends a lot on what your background fitness is and what you can tolerate. You have to place them in your training cycle at the right time for them to be effective. Right now is not the time unless you are training for IMNZ or some race in that time frame.
On an interesting note, my TSS was 288 at Kona. After doing rides in the 400’s it makes sub 300 TSS feel easy. Better for your run ; )
It was a 160 mile ride for 8hrs and the IF was around .8 if I remember correctly. I was shelled that night. I remember that the long run the day after went ok, but the heart rate was pretty depressed. A ride like this makes an Ironman seem easy.
