What’s the maximum spacer stack one can use on a fork and still be safe? 2cm? 6cm?
1", aluminum steerer, internal headset.
I think it all depends on the manufacturer of the fork. Check with them.
Cervelo fork… Not sure who makes it.
I saw on ParkTool a recommendation of 20mm.
I’ve also read or heard that height of the spacers should be no more than 1 or 1.5 times the diameter of the steerer tube, which would be 25mm or 37mm in your case.
Based on those reference points, a stack the size of the steerer tube (25mm) is probably o.k.
It would depend on the manufacturer. Check with them to be sure.
For Blue Competition/Aerus forks I believe it’s 45mm.
Hello LaWoof,
Cervelo Knowledge Base: http://www.cervelo.com/viewkb.aspx
Also I received the following reply from Cervelo (about a 1.125 steer tube fork):
Cheers,
Neal
The following is the answer to your question of 16-Dec-2006 11:08:36.
Question:
Hello Support,
What is the maximum steer tube length for the Wolf SL Fork when used in a P3C size 54? I am thinkiing of buying a new fork that will be lighter than my current Wolf aluminum steer tube fork (550g) for my P3C. I am using my P3C for Ironman triathlons. My front end set up measures 210mm from the fork crown to the top of the steer tube.
How does the Wolf SL carbon steer tube (about 350g) compare for aerodynamic drag with my current Wolf fork?
Please comment and advise.
Cheers, Neal nealhe@cox.net
Answer:
Hello Neal,
The Wolf SL gives you a maximum ideal stack height of 3 inches above the top of the upper headset bearing (ie the top of the head tube). If you are above this point you can always flip your stem over to get some extra height as well as using the 2.5 cm aerobar risers that are included with the bike. Another option might be to go to the Wolf CL. It is about 100 grams lighter then the Wolf TT but has the same lower as the Wolf SL and is priced $100 less then the Wolf SL.
The Wolf TT is a very fast fork but the Wolf SL and CL are faster yet. You will only save about an additional minute over an Ironman with these forks but for those who are looking for the fastest bike the Wolf SL /CL are very popular upgrades.
Thank you for your support.
Sincerely
Chris
Cervélo Customer Support
Wouldn’t it also depend on the stem?
As a general rule an unsupported spindle which is essentially what the steerer tube is can support 2.5 times its diameter. I’m not sure what safety factor is built into that however. I would be cautious about going over 75mm of unsupported steerer including all headset, spacer, and stem components.
-SD
Looks like I should be safe.
I have 60mm now and will drop to 40mm as the weight comes off and I get in better shape. Right now can’t really hold a good position because of by homegrown belly.
THANKS
