Marathon Weather
This Sunday is the Houston Marathon. The weather forecast is calling for light to moderate rain with temperatures dropping into the mid-30s during the race.
How would you dress for this? Would you even run?
Yes, of course you run it – those conditions are just about ideal if it doesn’t rain too hard. I’m a tights gal, so I’d wear tights, a light long-sleeved shirt, gloves, and a water proof vest.
Hey Matt:
Just checked weather.com at 1:30 PM Texas time. They are showing 30% rain with 61 at 7A.M. Sunday
Front supposed to be coming in around 12 Noon. Maybe all right with rain and a little warm to start but I think bearable if we can believe all of the forecasts. Am running in shorts and Tech T plus carrying a pair of dry socks in a Zip Loc baggie. Spent too long training for this to let the weather stop. I did race in 1997 when we had the snow & ice so I am not the best source of running judgment.
Good Luck to you Sunday!!!
fal7 in Sunny Houston
I agree with AmyCo, that sounds like PR weather to me. If there were wind I would go for tights, but with no wind shorts and long sleeve jersey, and some el cheapo gloves I could toss after the first few miles. Remember to keep drinking early on even if you don’t feel like you need it.
The forecast on NPR last night was little more grim. With the weather today, its a little hard to believe Sunday will be as forecast. Good luck to you as well!
That’s the perfect forcast for a marathon.
Unless its below freezing, the only thing that can slow you is wind. Cool temperatures are ideal. Layer in clothes you don;t mind tossing a few miles in once you get warm and they get damp.
Shorts, t-shirt, gloves, beanie, and armwarmers if its very cold. Thats all you’ll need.
Don’t wear anything in an attempt to keep you dry. No jackets, plastic bags or ponchos. The rain is not your enemy especially if it is 60 degrees as forecast.
AmyCO you are having flashbacks from last year’s Austin Marathon with all those clothes! 20 deg & sleeting at the start, icy bridges - I had shaking chills in my hotel room for half an hour afterwards. Good times.
Anyway Matt . . .
It looks to be in the low 60s at gun time, 40% chance of rain going to 60% by noon.
You will be fine in shorts and a singlet, but prepare to be wet, meaning. . .
  1. Wear a trash bag to the start and get rid of it right before the gun.
  2. Wear a hat to keep rain and road grime out of your eyes.
  3. Put bodyglide anywhere anything touches anything else. Especially as much as you can slather between your toes.
  4. PROTECT YOUR NIPPLES! Nip Guards, Band Aids, something to cover them. A wet singlet turns into a meat grinder after an hour in the rain.
  5. Do not under any cirstumcances wear any form of cotton.
Even if it doesn’t rain all of these preparations will serve you well. If it does rain and your feet are wet for long, you will have blisters after. So a pair of dry socks and a pair of sandals or slides in your sweat check bag will be your friend for the limp home.
Very best of luck to all this weekend!
I’m one of those fear-of-cold folks. I almost never get hot in tights (although if the forecast is in the 60s, it’d definitely be shorts for me). I like my vest because it repels water, but doesn’t trap heat. Again, I have this fear that if my shirt gets too wet, any little breeze will cause me to get cold and I hate being cold.
I also HATE being cold, thus my concern. I’d much rather the race be in August than January.
Thanks for the advice and encouragement, all.
Absolutely I would run–just dress right. Use layers that you can strip if you get too warm.
I ran Houston in 1997 in 31 degree windy with freezing rain–the most unpleasant 3:20 of running I have experienced. I ran in shorts with a singlet and light windbreaker, no gloves, and a nylon baseball cap. I got really cold by the end and wished that I had tights and gloves and a warmer top.
You must have enjoyed the Austin marathon then :wink:
I have probably felt colder than that a time or two when I lived in Montana, but I doubt my core temp has ever been as low as it was after 26.2 in last year’s Austin conditions.
John:
I would have killed to run a 3:30 that year in Houston. It was my first marathon and I did 4:54. I should have learned from that one; have done 13 more since that one.
Take Care
fal7 in still sunny Houston
tights
headsweats hat
thin to medium weight long sleever
vaseline all over feet (to keep away blisters in the rain)
shoes/socks
Biggest thing you need to worry about it if it rains your shoes/socks getting soaked. After about 10 miles or so it will start to be an issue if that’s the case. Blisters are huge possibilities then, and maybe even worse …
Wow! That sounds like great marathon weather - layer up, lose the layers as you progress and heat up, and have some warm/dry stuff waiting at the other end. Good luck - have a great race.
Matt:
Weather this morning for Sunday: 63, scattered showers. Front may be in by Noon. Some folks may want to pick up the pace.
fal7
Things are looking up!
