If I can give any advice from my past 7 marathons (not including IM). I’ll lay down my nutrition plan for the 2:57 I ran in Chicago last weekend.
AM(pre-race)
Granola (couple handfuls) and banana +immodium tablet. (The immodium stops my stomach from getting gassy or bloated) I’ve used the immodium before and it helps stop any discomfort.
Made sure I was empty and headed to A corral.
I’m not one to “carb up” 15-20 before so I don’t hit a gel before I race. I do however swish my mouth with gatorade, and then hit a little water right before I get to the start line (they usually have cups before the race)
In my training I always try to hit nutrition every 4-6 miles, I have a very active and high metabolism so I burn through things quickly.
I use Hammer gels and shot blocks. I have a spibelt and it doesn’t bob at all and is very comfortable.
I throw in 4 gels into the belt and then a pre opened package of shot blocks. (have you ever tried to open cellophane with sweaty hands? IMPOSSIBLE)
I took my first gel at 8.5 miles when the aid station was in sight, this allows me to get the gel down and then follow it with gatorade. I take sports drink every aid station up until 15.
Second Gel: 14.5 (again within sight of an aid station). I switch to water at this point because I’ve found no extra help from the gatorade (it only makes me have to pee).
Third Gel: 18-19 This gel is usually espresso with extra caffiene which helps me get over that 20 mile hump.
Fourth Gel: I take this religiously at 5K to go, I usally take another caffienated gel just to keep my blood sugar and the caffiene helps give me that last kick. (I’d say it works with my last 2 miles under 6:30 pace :D)
I only had 3 shot blocks the entire race. This was mostly between 9-15, it was a long stretch and I wanted soemthign solid to chew on and I always pack more then I need for a marathon. I have celiacs and I can’t have most on course nutrition (GU clears me out (not in a good way AT ALL)). I always pack 1 more gu’s worth of nutrition then I need. for 2 reasons: I drop shit, alot… 2. In my first 3 marathons I’ve had people hit the wall and have been able to help them out. 2oz of nutrition ain’t gunna slwo your roll and it’s always nice to get a thank you after a race…
As for fuel belts and other drink carriers: I’ve used them all, back packs to belts and I like my amphipod belt well enough but it’s only really necessary if your in a trail ultra or mary and there are only 1-2 aid stations or it’s VERY HOT.
IMHO the course is setup to provide plenty of hydration and you should be fine. Do yourselfa solid and review the course nutrition/hydration layout. I’ve tried it all in 7 marathons and this method of gelling every 4-6 miles worked extremely well. I had a very comfortable race and I had the energy and kick to put it down the last 3 miles.
I’m no guru but, I’ll do what I can to help.
If it’s a local race and you can manage to grab a water bottle from someone around 18-20 (don’t rely on it bieng there), try something a large group of us used in Kzoo this spring: 1 redbull+ gatorade powder (or gatorade) mixed with a little water (just to get it to titrate fully). when you get it shake it and slug it. Caffiene +electrolytes +hydration, it’s a kick in the ass and it’s awesome!
