I just ordered a set of RT8’s. They are coming without pad holders.
What pad holders do you guys recommend?
I did get a new set of Reynolds blue pads for the Aero 72’s I have.
Thanks
The pad holders are the metal bits that hold the brake pads. So I’m guessing your question may actually be about which pads to get. If that’s the case then it depends what type of wheel you’re using - alloy v. carbon. If you want some more feedback it might be better to change the title of your thread to the best pads for the type of rim you’re using. If that is the case then the Magura and pad holders are irrelevant, it’s the brake pads and the type of wheels you need to deal with.
I did not know if the pad holders are universal?
With the shape of the Magura calipers, will any brand work?
I found some KCNC holders that look nice. The black will look better than if I just use the holders off my old scam force calipers that are grey in color.
Also noticed a couple brands but I did not want to order them and install only to find out they are hard to get thew brakes dialed in because of shape or the like.
Thanks
