M Frame with Giro Advantage 2
Just ordered a Giro Advantage 2 helmet, do Oakley M frames work with it or is the helmet to narrow?
good question. any giro a2 owners that use M-frames have any thoughts ?
There should be about 1000 pictures of pro cyclists with this combination. Especially in last year’s Tour.
http://grahamwatson.com/gw/imagedocs.nsf/updateframesetcall?openform&06tdfPr
http://grahamwatson.com/gw/imagedocs.nsf/updateframesetcall?openform&06tdfSt19
I dont know how thick the m frames are but my rudy project sportmasks slide in with no problems
This depends on the size of the Grio advantage you wear and how well it fits you.
If you are like me the Medium Advantage 2 with M frames is a no-go. It will work well with the narrower (newer) earstems on Oakley Radars. Radars are specifically designed to work well with helmets, especially aero helmets, due to the lower profile ear stems.
much more later…
I use a large Advantage. I have used M-Frames, Pro M-Frames, and Racing Jackets with no issues.
