On a ride yesterday I had a flat on my front tire. Changed it, but when I got back on, noticed a thu-thump…thu-thump. Got home fine, but have no idea what’s happening. The wheel appears true laterally, and when I spin it with no tire/tube, there is no obvious malformation. Put a tire on it, and there are two noticeable “flattened” sections of the tire. I’ve tried different tubes, and different tires. Same result. I thought maybe the rim tape inside the wheel was preventing the bead from catching correctly or something, so I replaced that. No change. It’s almost like the tire is somehow seating lower on the rim in these spots. Any ideas??? Am I missing something that’s obviously wrong with my wheel? Is there some stupid thing I’m suddenly doing on the install of the new tube/tire that I’m just not aware of? Thanks for your help!
could be that the tire is ruined
did you ride on it flat for a while?
happens to me if you happen to get a tire that is a little tight for your rim. A little lube will help it seat right, and it might take a few trys to get it seated correctly. Usually a new tire does this more than an older one, but I had one that I fought with all the time until I finally gave up on it.
FishHog
I’ve had that happen. Sometimes you can grip the tire and ‘roll’ it up until it seats properly. You can also try overinflating to see if it pops in. I have also heard of using soapy water on the tire bead.
Could it be that the stem isn’t pulled all of the way through?
I don’t believe the wheel is ruined…there’s nothing obvious to suggest it. It spins pretty true. Is there anything not obvious that I could look for? I rode it only a little ways - it was a slow leak, not a pop, but nothing too extraordinary.
The lumpiness is happening on two different tires, neither of them new.
I’ll try the soap and water trick. In general, though, seems this is common enough. Weird.
