So, I bought a lactate meter before really researching how I would use it. Naturally I’ve now learned, as Paulo said, that the field test is probably as, and in my hands probably more, reliable. But I have my new toy and my friends and I want to play with it.
So my questions for the run protocol:
The USOC run LT protocols focus on the 10K race pace. The goal is to do graduated steps of 3-8", ideally reaching steady state @ each step. After each step, but ideally continuously running, the HR and LT are recorded. The goal is to do it in less than 30". A rest is then taken and it is repeated with graded steps but now with increase in gradient, not speed. Things I would question if I had access to an exercise physiologist.
10K for olympians take about 30". If a 10K for me takes 45" should I start @ a lower speed? They have the subject start @ 40meter/minute less than racepace then increase by 10 meter/min. For a 45" 10K that is 6.8 mph then increase to 7.15 then 7.5 mph. I know I’m nowhere near peak condition but I’d be done pretty quickly. The goal is to get 2 base #'s then start to see a rise. Bear in mind that when doing a field test to approximate LT you are going hard for 30" then taking your average HR for the last 20". I’m thinking maybe you base it on the speed that you can maintain, but finish pooped @ for 30".
3-8" is a pretty big range. Most people do 3-4". Is the steady state reached most quickly by elites vs conditioned age groupers vs out of season age groupers vs couch potatoes. I’m kinda thinking 4" is a good balance.
Why the gradient thing?
And a shout out to folks who do this professionally. Honestly, by the time you pay for the meter and test strips and account for time $100 for a LT is very reasonably.
I bought a lactate pro tester since I can’t get tested where I live. I did a test on the track and if you are very careful with how you test in terms of keeping everything sterile, having alcohol wipes to get rid of sweat which can give you bogus results you can get pretty accurate readings. I have done the test on the treadmill running four minute steps as well as doing it on a track.
I then got tested by a top sports lab and the raw data was very, very close. IMO the real value of the test is having someone who can interpret the numbers for you. Some of them are very obvious. But the real value is to have someone who know what they are doing to sit down with you, go over the data, and then tell you how to best use it.
I agree that if you just want to set up zones then a field test will get you good data for that.
Will is right with this. Let’s assume you get some good data points at a given HR for THAT DAY. Say you cross the 2.5mmol at 174 HR and 4mmol at 183. Great, but now what? Do this every 4 mins, plot out a nice graph, see where you are no longer linear as the slope steepens for your LT? Do you do this again in 1 week when more rested, better weather, without caffeine? Average out the HR data?
Honestly, I’m not totally convinced of a good coach either (sorry Paulo), but you do need someone to help you understand the numbers, validity and most importantly what to do with said numbers.
If all you do with lactate testing is take out HR zones, then it’s a complete waste of time. But perhaps all those great coaches that don’t have time to post on ST, even though they read it all the time, can find the time to add to this.
Many people don’t realize there are more than a few dozen (last I looked over 40?) different protocols for a GXT. In a lab test, it’s repeatable and controlled. This may be the OTC’s protocol, but may not be the best for you.
Rule #1 for all tests- they have to be specific for the subject. It’s like having Khalid running an Ebbling protocol (which may be better for a phase IV cardiac rehab patient). Make sure the test is going to work for you, and then repeat the same test later.
For your ?'s-
What is the goal you’re hoping to achieve? With regards to doing a GXT (which is a good education, but not always practical for athletes), a couple years ago East Carolina U. did a comparison of the VDOT, 3200m, 30min, and Conconi test, and the 30min was nearly the most ideal and practical for estimating velocity and HR at LT. Something to think about, since you’re also talking about a 30min field test.
Stages in a GXT are standardized if you’re using a specific protocol. Depends on the test. But when it comes to hitting your steady state, at the same given workload, the age grouper and coach potato will typically hit their relative HR/blood markers before the well conditioned.
Gradients assist with getting the intended response. You’ll “recruit” more physical effort to run/ride a gradient than level. Conditioned athletes have a lower lactate level at a fixed workload, so the gradient increase (if your protocol calls for it) assists with this.
One note of caution though- be careful getting test samples while running on the treadmill. I haven’t had a participant fall, but did see a classmate touch the treadmill deck while having his blood draw, slam down on the tread, and get a nasty tread burn on the chin (7th stage of a bruce protcol. Treads only going @5mph, but the incline is way up there).
Yup - it is a waste of time. I’ve not had a coach yet (when used) who wanted or asked for any blood samples (for any measurable level, including narcotics ;-). HR data (amogst others) he did.
Paulo, thanks for the bump and the lack of “I told you so”.
Trevor, for heaven’s sake, I’m a 45 y/o F, that’s in a tri. I know it’s not blazing but for my age group it isn’t that sucky,
Rob, I saw the protocol initially on Letsrun so not as good as seeing it from a usoc site. I do have an ex phys book that goes over the limits of the tests. I agree with the previous posts. Getting the data has some challenges but is doable. The real brains comes with knowing what to do with it. It’s definitely more subtle than I had thought when I paid someone to do it for me.
I have used a Lactate Pro for 5 years now. I rarely use it now as there are so many good, easy field tests (or races…) to get data from. I will use it on occasion for threshold type workouts while skiing, but that is it.
That said, you can get a few good test protocols from the www.fact-canada.com site.
Not an ass but 32 min, shoot that’s pretty fast. Hijacking my own thread I guess i would argue that slow folks should train in the same spirit, even if not as fast, as fast people. That’s assuming they’re slow due to body type/efficiency/strength and not lack of fitness.
Ahhh, interesting. I didn’t really “get it” from their explanation so I googled some other sites. So Lactate balance point is the thing. It looks like you measure HR vs effort until you reach a point of “high” lactate accumulation and measure lactate there. Then you drop HR by 40bpm, keep it at the lower rate for 5", measure, increase 5-10 bpm for 5" measure and keep doing this until you find the lactate nadir. The graphs suggest way less guess work and more reproducibility. It seems this is also a way to guage overtraining. Paulo? Is that what you were referring to as the best use of Lactate?
The problem I see with this is that you’re taking a point (which is VERY argumentive depending on where one defines the LT), and making it more dependent on HR. If anything, HR should be dependent on where one defines the LT. In other words, if one person defines LT at “x” point for test termination, then the LTHR will be the HR measured at “x” termination.
What I believe PS is also referring to is just how practical it is to use a lab assessment in a “real world” situation. If all you’re looking for is an HR range to work off of, make it easy and more realistic and go by HR. I would have to agree as well- get a reproducable, real-world, easy protocol and test off of that.
If you want to use the analyzer, I would say only use it on “bench mark” days every 4-6 weeks (ex: assessment test).
One thing that always comes to mind with this topic is about 7 or 8 years ago when people gave LVL alot of press before Hawaii one year when he was trying to come back from an injury. His coach kept on saying “blah blah blah, LT levels are excellent, blah blah blah, LT is perfect, blah blah blah.”
Couple days before the Big Dance, Mark Allen was interviewed and asked to comment on it…he just said (to paraphrase) “Perfect LT levels don’t win Hawaii.” I believe LVL DOR’d that year. Only reason I mention this is to keep things in perspective. I’m a big proponent of all tools to gain improvement, but it still comes down to game day.
You lost me a little. When you say “the problem…with this” do you mean the lactate balance point or the USOC protocol I threw out? I did get the meter to try to figure out training zones based on HR. The thing I like about the LBP protocol is you aren’t guessing with the curve. You’re kind of nailing down, “well @ this HR you start to see lactate rise”. I.E. this HR is where acid accumulates and you can no longer utilize lactate as fuel as well.
I don’t think there is any doubt that all these #'s/zones have to be looked at within the context of the environment/diet/stress that you bring to the workout or race. Many of us probably forget that.
I couldn’t find that lactate balance point test link, but if it’s based on HR and lactate, THROW IT OUT THE WINDOW. Lactate tests are to be done using pace/power and lactate. HR zones that you might derive from them are secondary and should be seen like that, HR zones. Like Rob said, lactate tests are more useful as control tests every 6-8 weeks. For a resource with some very decent stuff on lactate testing, get Maglischo’s book. Another good resource is Olbrecht’s book, but I’m pretty sure you’ll have a tough time getting your hands on one copy.
as Paulo states, Pace is the metric and what we are “training” here. As I stated, I no longer use an invasive test for my summer sports (swim/bike/run) as there are many field tests that I can use along with tools (power meter for instance) to determine a “threshold” number that I can train.
for skiing, pace is tough to determine as snow, wax, ski flex, technique can all lead to different paces at similar HR’s. I tend to use the Lactate Pro to keep my “honest” in my pacing for longer intervals during the season. So last week, I did 4 x 10min at ~50K pace, lactate was taken after #1 and #3 and was 4.4 and 4.6mmol for each. The loop I was skiing is measured, and I was within ~5 seconds for each rep, but PE and HR response rose for each set.
