I just had my annual physical and it was discovered that I had low RBC/WBC counts…am under the assumption that this is related to an immunodeficiency?? I haven’t gotten sick that often over the past years but did have a severe asthma attack which lead me to be pulled off the bike course at mile 100 at Kona this year. My oxygen saturation dropped pretty low and I was hypertensive when taken off the course…could have this affected my bloodwork? Anyways, I was wondering if this is something I should be concerned about or need further check up on? Any doc’s able to help me with this?
Kim, I know that having low RBC would be a concern, what is your Hgb? As for WBC if that is low not sure, but what does your doctor say? I have a rare bleeding disorder, so when my RBC is low my Hgb is usually low as well. I would talk to your doctor and do some research on your own. Doing research on your own is always good. Did you get a copy of your labs?
My iron levels (hemoglobin/hematocrit) are normal. I haven’t found any thing definite in my research of the issue. A low WBC count is indicative of a depressed immunity although I haven’t been sick for a long time. This is all fascinating to me since I am interested in physiology…just thought I’d try to get some feedback from any athletic docs on this forum. Healthy trails, Kim Brown, MS, RD Sports Nutritionist www.kbnutrition.com
Your hematocrit (% of red blood cells in serum) is usally about 3 times your hemoglobin level. If you are anemic, there are a lot of different types and reasons why. Need to know your RBC morphology - my first guess would be iron deficiency anemia (based on most common). However, most endurance women athletes (if you were at Kona, that certianly counts) have little to no menstration anymore.
A single lab test with a low white blood cell count means very little in the abscence of other symptoms/lab findings. Repeat the bloodwork in a few weeks. Also, there should have been a breakdown here as well (%neutrophils, etc.)
I’m not a doctor, but I believe your WBC is only to be elevated when you ARE sick. Isn’t that what they are for, to fight (actually eat I believe) off things that aren’t supposed to be in you? Your iron levels and your hematocrit and hemoglobin levels are not the same. Did you get any paperwork for you to look at? If your hematocrit is around the 37% mark it’s kind of low for a female, as with readings under 13 for your hemoglobin. Any hard numbers for those two indicators?
Another flag was BUN/CREAT ratio being elevated (31.4) and creatinine being low (0.5 mg/DL)
Lower-than-normal levels of creatinine may indicate: Muscular dystrophy (late stage) Myasthenia gravis
Elevated levels of BUN/CREAT ratio may indicate
Considered together, the BUN, blood creatinine and their ratio give very good evidence of the filtering function of the kidneys and also, a measure of the degree of bodily hydration. The ratio of BUN: creatinine is normally 10:1. With dehydration, the ratio can increase to 20:1 or even higher. This makes sense because I came from a very intense workout that morning and most likely was a dehydrated…spent the rest of that day rehydrating.
I do have books/access to information as everyone else does but thought I may gather some better input from specialists, doctors who may give me something a little more valuable than textbook knowledge. I am always looking to expand and by outreaching to other professionals in forums like Slowtwitch, I find myself learning more valuable information than what can be found in books.
I guess my outreach for help is very much like a coaches/doctors asking me for my expert knowledge on nutrition even though I am sure they have at least a textbook knowledge on the subject.
Your WBC is lower but you don’t seem to have a specific population affected (lymph/PMN/mono percentages are all normal).It’s pretty nonsepcific - did you just have the flu?
Your creatinine is also related to your muscle mass (as well as your kidney function.) More muscle, more creatinine. The BUN is related to protein intake as well as kidney function. The elevated BUN/creatinine may be related to relative dehydration, as well. If you consume a lot of protein and have a small muscle mass, this could effect the relative ratios.
Your total granulocyte count is normal, so the lowish WBC count probably is OK. Your red cells are borderline large, so your RBC count will be lower for the same Hemoglobin level. Large RBC may be related to reduced B12 absorption or decreased folate intake. Hemolysis can give you largish RBC’c as well. A reticulocyte count, folate and B12 levels might be instructive. But, most likely these are normal variants. I’m not an adult doc, so you might want to confirm this with an internist or hematologist.
Don’t think I have the flu although it is funny that you mention that cuz when I went to go see the doc, I hadn’t been able to keep anything in my system and was running a slight fever…I related to something new I ate but suppose I could have had a bought of the flu. And the combination of my intese workout I did that morning and not being able to hold anything in my system explains the dehydration and BUN/CREAT abnormality. Smartasscoach…hearing such input from experts, people who draw blood and look at blood chemistry values every day, is why I am on this forum cuz the info is far more valuable than regurgitated information from a textbook.
Yes, you are correct in that you always have to be careful as to who you take information from. When reading responses from others, I do my own homework too to make sure the information meshes with what I know to be true. I also seek out personal help from professionals I network with in the area.
