So, I’ve been working through this for a few months and figured I might as well ask ST to share some of its collective knowledge on the subject.
Background:
About three months ago, I was hit by a car while cycling. Fortunately, I was going uphill and the driver accelerated through a stop sign into me (I did not have a stop sign), so speeds we low. I went up onto the hood of the car, and when the driver stopped, I was thrown onto the ground. I have since had my bike’s fork and my helmet replaced and the driver’s insurance company has claimed fault for the accident. I’m 25 years old.
Unfortunately, I’ve been dealing with back issues for most of those three months.
Treatment:
Following the accident, I had an x-ray to rule out rib fractures. None were found.
Back pain (lower right side, between L3 and S1) continued and I began seeing a physical therapist about 2 weeks later. I went to therapy 1-2 times per week for about 8 weeks. Initial responses were good, and the muscles in the affected area began to loosen up and feel better, except for one area which, whenever the therapist did trigger point techniques, would send me through the roof with pain. I still have this reaction to that spot but improvement of the area as a whole seems to have stagnated over the past several weeks.
A couple of weeks ago I saw an orthapaedist on the recommendation of the therapist (largely to rule out fracture of a transverse process). I had an MRI which, apparently, didn’t show much (besides no obvious fractures) and the orthapaedist said the likely culprit is a L4/L5, L5/S1 facet joint sprain. He put me on an anti-inflammatory and said if it doesn’t do anything in 2-4 weeks, that it probably wasn’t going to help. So far, I don’t really notice a difference with the medicine (it’s been about 2.5 weeks). Orthapaedist says the next step is steriod injection, but that I may continue my current training load, which I reduced from about 10-15 hours per week to 5-8 hours per week following the accident. I can make do, but the situation is far from ideal.
The physical therapist believes I may have an adherent nerve root at L3 due to some of my symptoms (area of pain, point sensitivity, occasional tingling in right side of quadricep when pressure is put on the spot, level of discomfort while exercising).
Personally, I would like to avoid a steriod injection unless absolutely necessary, especially since I get the feeling that the orthopaedist mostly wants to use it primarily for either confirming or ruling-out the sprain. The physical therapy route for either injury is different and more time consuming and since I don’t really know the cause, I’m pretty confused on what to do.
So my question(s) is (are): have any of you had similar injuries or symptoms? Was there anything in particular that keyed you one way or another? What were your treatment options and how did you proceed?
Any help is much appreciated!
