Looking for Orbea Ordu Stack and Reach info
51 or 54
thanks in advance
Size Stack Reach
51 512 396
54 520 410
I finally have good geometry data for Orbeas so these numbers will be accurate within a mm or two.
Do you have the stack and reach info for a 48cm Ordu? Also, I’d like to know the front center if you have that as well.
Thanks
stack reach FC
499 379 575
that was fast. thanks
Any chance you have stack/reach on a 54 ora??
same as ordu listed above - frame is out of same mould but uses different grade carbon
Not any more… they’re totally different bikes.
http://bp0.blogger.com/_SlGUavlY8R4/RsM84in9F1I/AAAAAAAAAA8/5AAUvB_4DnU/s400/OrbeaOrdu.jpg
http://agouracycles.com/images/library/large/orbea_ora_red_08_m.jpg
the ordu geom I listed was for 07. 08 has only changed fractionally. I would characterise them as slightly different bikes.
Would indeed. The things you learn on here.
Size Stack Reach
51 512 396
54 520 410
Don’t suppose you could tell me what the 57 is ?
Thanks
http://i31.tinypic.com/210x9ps.jpg
