1)use alien clamphead for std posts: $6
use alien unused bolts, set of two: $5
2)itm the stem, magnesium, 130 mm, used slightly: $85
itm the stem, magnesium, 130 mm, used twice: $115
3)token bottom bracket, carbon sleeve, ti spindle, isis, english, UNUSED: $55
4)FSA ISIS bottom bracket, carbon sleeve, ti spindle, english, used for 50 miles: $55
5)campy record carbon crankset, 172.5 mm, pristine condition: $390!!!
6)FSA bottom bracket for campy crankset, carbon sleeve, ti spindle: $55
7)stronglight pulsion chainring, 53 teeth, unused: $26
8)fuji 2 lb frame, 49 cm, perfect condition, with headset am classic ultralight, reynolds ouzo pro fork or alpha q sub 3: $450 with reynolds fork, $495 with alpha q sub 3
9)ZIPP 58 mm rims with am classic hubs, under 400 miles, 700 c, shimano, tubular, rear ONLY: $390
- Deda Synapsi Carbon bar/stem/aerobar combination, 120 mm stem length,size 44 end to end, 42 cm center to center: $295
- Cable adjusters, plastic, modolo, UNUSED, to attach to frames with shifter bosses on the side of frame, superlight: $10
mike at mlimm123@yahoo.com
