Just did my first test ever on the bike. It was indoors due to the weather conditions here in MA. I don’t have a computrainer nor any speed/cadence devices. Basically, did a 30 min TT on the trainer. I did a 10 min WU and then started. After 10 min I hit the lap and recorded for the next 20 min. By the end I couldn’t put much more effort into pushing the pedals any harder. My average HR for the last 20 min was 149. I’m currently using Friel’s TTB and my 149 looks pretty low on his charts. Good thing is that I have been doing my recovery rides and Z2’s properly w/o even knowing it.
I’m scheduled to due my run test on Sunday, but it appears as though it is going to be very windy up here. I’ve got a nice flat course I can run to do the test but w/ the wind I’m not sure I’ll get accurate readings. I always have the option of doing the 30 min TT on the treadmill but I’d prefer to do it outside because that’s where I always run.
I’ve just begun to take the HR training seriously and I want to get accurate #'s so I can get the most/recovery out of my trainings. Should I do the test indoors or outdoors?
I just did a Lactate test on the treadmill and it really dialed me in.
I can’t see using a heart rate monitor anymore without one.
Consider that doing it outside will bring enviormental conditions into play , I’d recomend doing it on a treadmill…
I guess I don’t understand how a windy day is going to influence your numbers if you are trying to establish HR based training zones. A hot day will drive your numbers up, but wind’s main influence would be on your pace. If you are trying to do something else, like establish paces per Daniels’ Running Formula, the wind would make more of a difference. But really the Daniels model is based on race results, not TTs done by yourself. Races always bring more out of people.
If you run outside, I would test outside as most people have reasonably divergent HR numbers indoors and out.
“My average HR for the last 20 min was 149. I’m currently using Friel’s TTB and my 149 looks pretty low on his charts.”
Don’t let that concern you; some folks just have slower hearts. That’s generally indicative of a larger heart with greater stroke volume, so your cardiac output at 149 might be just as high as someone else at 190.
Tests are always best done under stable/calm conditions but most importantly, the conditions should be repeatable. Some wind won’t have that big of an effect, and really zero effect on finding your LT. But the data on how long it takes to cover the distance, or how far you go in the time period is valuable, but only if you can repeat the test under the same conditions. For this reason, it’s usually preferrable to do your tests indoors.
Environmantal conditions can have a huge impact on HR. For example, some studies publshed in the book Physiology in Sport and Exercise:
Maintaining same speed on a treadmill was 165 bpm at 70 degree F, and maintaing same speed was 190 bpm at 95 degree F
50% humidity was 165 bpm, at 90% humidity 175 bpm to maintain same spped
Small meal 30 min before exercise 165, large meal 30 min before exercise, 175 to maintain same spped
8 hours of sleep 165 bpm, 6 hours of sleep 175 bpm to maintain same spped
The time of day you exercise can effect your bpm by up tp 4 beats, based on your circadian rhythms. Exercising in the morining is about 4 beat less than afternoon.
In summary, I believe that you should do your LT tests as close to race-day conditions as possible, and perform your test outdoors. Obviously, this can be a challenge and race-day weather is completly unpredictable. This means regular LT testing (monthly) and noting the environmental conditions in which the test was done, and possibly adjusting your zones on race day based on experience and feel.
