Other than yankz, what other brands or websites sell these easy laces. I need to purchase a pair for Eagleman
Thanks
Thanks
xtenex are nice. they are a pain in the ass to set up the 1st time, but they are great after.
knotty boys
10,000% better than Yankz and cheaper than Xtenex (not that they are all that expensive)
Yankz are just so unforgiving on a long run if you don’t have them PERFECTLY set up. Switched to Knotty’s and never looked back.
I like lace locks. The are alot easier to get adjusted then yankz.
Thank you all. I will certainly check them all out.
ibungee trisports.com has them
Also, where is a good place to buy any of these? Knotty boys I have had trouble with.
I like Lock Laces. Easy to setup and easy to use. Nothing fancy, very simple.
http://www.locklaces.com/
Just a suggestion. I’ve tried most of the elastic laces and finally settled on plain old 1/8" round elastic from a fabric shop (my wife’s idea). Just lace up you shoes as normal only using the elastic. Set the tension where it’s comfortable then tie it off with a very tight square knot. I cut the loose ends off at about 3/8" using a hot knife so they don’t unravel. I use this both on my flats and my Nike Free’s. Seems to work well for the life of the shoes. I know it’s not very “trick” or cool, but it works well.
I use knotty boy laces but cant seem to find them in Australia anymore but they are a kick ass lace…easy to slip on in t2 and u dont have to worry about a piece of plastic
Thanks
x3 on Lock Laces. Easy to set up, work perfectly. Cheap to buy directly or via Amazon. I much prefer them to Yankz, but all of this stuff is obviously personal preference.
x2, they are easy to lace up and pretty cheap. It’s the only brand I have tried but I don’t see the need in trying any others.
