So the gram scale was busted out and medium Kalibur weighed 1060 grams. The P3C 55cm frame only weighed 1359 grams, the seatpost weighed an additional 306 grams - this puts the Cervelo at 605 grams more than the Kalibur.
Thoughts?
Thoughts?
Fascinating, really. If I had a Cervelo I would sell it immediately.
Chip…
My fully kitted out (well, no water bottle cages) Kalibur with full Ultegra, Reynolds Alta Race Comps, Michelin Pro Race 2s, Profile T2 cockpit, and Arione Tri saddle was right at 18 pounds…don’t know if that helps…
Spot
Frame only… does that mean no fork or headset? Sorry for what might be a stupid question.
Thoughts? for a TT/Tri frame aero trumps all and I “think” the P3C is more aero, so the weight advantage is naught. But hey, a pound and a half is something … It’s not like Cervelo can’t make superlightweight frames (i.e. R3 or even a SoloistC that is pretty aero) - they just make what they need to for it’s given purpose.
I’m surprised the Kalibur is that light though with that really beefy headtube and 1 1/4 inch bottom race.
But I thought that aerodynamics matter more than weight? Perhaps the Cervelo is more aero, or enough to trump the difference in weight.
It doesn’t seem to bother Team CSC. Were talking about TT bikes here, the more aero the frame the faster the bike
What about fork weight? Seems likely the Kalibur fork is also lighter.
My first thought: that P3C frame/seatpost is about 200 grams lighter than my old P3–and a P3SL would be even lighter; which in turn, means the P2C weighs about the same as an old P3SL, at twice the price, with a very questionable aerodynamic difference.
As far as the Kuota vs. P3C, all I know is that it doesn’t take much of a drag reduction to overcome a 600 gram weight penalty–even on a hilly course.
Just looking at the tubing profiles of both bikes, I would think the P3C would be faster under almost all conditions.
Just thought i’d contribute some weights from the www.efbe.de website.
They weighed:
53cm P3C - 1240g
58cm P3 - 1610g
By the way, the Cucuma L06 (one of the Walser models) in 58cm came in at 1725g.
to compare the weight of 2 time trial frame like theses two is about as relevant as comparing there colors…no impact on performance for triathlon. Weight is only a bragging right thing… i been very fast on a 25 pounds softride classic beam and never had a problem keeping up in the hills…desert dude will tell you the same.
how much does the seat post weigh on the kalibur? or did you include that int he original weight?
As will I…never had an issue on the hills at IMLP on my Power V, then Rocket frames…
Funny how everyone is so defensive about this subject.
who cares?
that would be my thought ![]()
I also seem to remember Jurgen kicking a few “lighter” bikes asses going up Palomar back in the day (on his “tank” of a Softride) ![]()
I was thinking the same thing.
It’s like R10C went on a religious forum and said, “There is no God!”
Let me put down my slice of pizza so that I can way in on this MAJOR weight difference, oh never mind.
9 out of 10 ST recommend Cervelo, the other guy is just un-cervelocated
It’s about time that bike came in. I thought you were getting a Large though?
Good luck with the angio tomorrow.
Thoughts?
Thoughts?
