Hi all,
So I’ve had some pretty good success training by power over the last couple of months.
I would say that in racing however, I have raced *with *power rather than by power over the same time frame.
Over the 1/2 IM distance and below this has not been a real big problem, I feel like I’ve paced the bike aggressively but it has worked out OK, I have used the data from racing to guide my training (as opposed to it dictating my strategy in the next race)
I have been using a disc cover for racing…obviously that’s not allowed in Kona so here are my options:
-Rent 606 with PT from Raceday wheels (I’ve already got a set reserved, this option will end up costing ~240 USD)
-Use my cycling clubs 404s, no PT - these will be free
-Run the 404 front with my Mavic CXP 33/PT Sl rear wheel
I’m leaning towards one of the free options but I’m still willing to consider the wheel rental
I’m a strong cyclist, I want to do well in Kona and nail the whole thing, I also want to keep the price manageable (and yes the 240 US makes a difference, it will mean the budget/credit card will be stretched more than it already is…definatley pushing my comfort level for a ‘hobby’!!)
Thanks folks, Ian
Is it cheaper to rent a single wheel? IE, rent just the rear with PT hub, and borrow the 404 front from your club?
What is your goal for Kona?
I just rented 808’s from racedaywheels.com and it worked out great.
Using your PT wheel doesn’t sound like the fastest option.
Hey Ian,
If I read your post correctly, you have enjoyed having your PT along for the ride in your races since the data has been valuable for use in training. It also appears that you are happy with your choice to train by power and race by intuition.
Are you thinking of changing your tune for Kona? Do you plan to do race simulation rides by power and set up a race plan with power goals, ceilings and all that? If so, then having your rented PT would be useful (although you would have to test that the readings agree with your training wheel).
If you are sticking with your “Race with PT for data collection only” strategy, then you simply need to decide if the data is worth the money (and cross calibrate as mentioned above).
The tech-data heads on the forum will chime in with more educated guesses than I could give in terms of actual time savings, but clearly the borrowed 404s are the cheapest fastest option for you. Running a PT (yours or rented) is heavier, but I think most would agree that the Kona course does not penalize on weight nearly as much as on aerodynamics.
One final note: If saving the money allows you and your wife to do something cool on the Island that you otherwise wouldn’t, it’s a no brainer to me!
Thanks Mike!
I think I’m gonna go with the club’s 404’s. I hope I’m developing a good enough ‘feel’ for my effort after putting in some quality long rides over the next 8 weeks or so.
Have a good one at Timberman!
Cheers, Ian
I saw that you felt like the decision was done, and I can appreciate why you’d go with the 404s. As a power geek/advocate, I would feel remiss if I didn’t throw one word of caution out there. There is often a pattern for athletes who have pushed the envelop a bit successfully at half IMs to try the same at the IM, and they often lose. Power provides the best means to monitor and marshall your efforts on the bike. Just my $0.02.
Jason,
Thanks, I’ve turned into a bit of a power geek as well, so my mind has not yet been made up. Bottom line is I’m going to Kona to achieve the best result I can. I am however limited in the amount of money I can drop in pursuit of this. I’ve got the wheels reserved and I haven’t had to make a deposit on them. I’ll continue to pay very close attention to the RPE, HR and power relationship as I try a few different thing during race sim. rides.
Hopefully that’ll help!
Thanks for the input,
Ian
I’d go with the PT on race day. My experience was that the Kona course is a little deceptive in terms of how much work you think you’re doing vs. how much you’re actually doing. The first 20 miles are pretty easy but then you start hitting some rollers that are easy to let get away. The road to Hawi is the same, as are parts of the Queen K on the way back. And if the wind kicks up then it’s a whole other story.
The best advise that anyone gave me, which I failed to follow propertly, is that the race starts at mile 80 of the bike. If there’s a next time, I’ll use a PT to keep a lid on how much work is done up to that point.
