Kona question re taxis
Roughly how much is a cab from the airport to Ali Drive for me and my bike (in a bag)? Plus, I’m assuming they are relatively easy to get, i.e just hanging out at the airport and don’t need to be scheduled.
when do you arrive?
It’s about $25 for a cab from the airport to town, and the cabs are plentiful.
You can also check with your hotel about shuttles that may be less expensive.
$25-$30 from the airport to the pier.
Cabs are plentiful, rental cars are outrageously expensive.
They are pretty expensive I thought. Last time, the cab only accepted cash. You’ll be best off walking up to someone to see if they want to split a cab to town with you.
Thanks for the info guys. $25 seems reasonable to me.
way more than $25. Count on $40+ without tip
If you’re getting charged $40+ from the airport to the King Kam/Uncle Billy’s area of Alii Drive, you shouldn’t tip because you’re getting screwed. I’ve made that trip dozens of times, and I’ve never been charged anywhere near that much.
http://hawaii.gov/koa/ground-transportation/taxi-cabs
This sounds a little more accurate. $40. I know it is crazy high/expensive. If you know someone going with a car, have them pick you up & then tip them $15 for the ride & a beer after the race.
