Clearly it’s possible (as some have) to qualify at that weight, but I think one of the major challenges is that most athletes that size (that have the right combination of physiology and biomechanics to go mid 9hr range) don’t tent to gravitate towards endurance sports, so the pool of talented endurance athletes at that size is very small.
When I ran xc/tf in college, I was 185lbs and was 30lbs+ heavier than any teammate, and can’t recall ever racing against anybody at/near my size, in any race over 800m. And I just stumbled into distance running in HS. I was trying to get in shape for soccer and wanted to be a hurdler, but my friends (whom I carpooled home with) were distance guys, so I ended up becoming a distance guy, on doing surprisingly well.
But none of the coaches in my HS were going up to other 180lb guys and telling them they should be distance runners. The only coach who every approached me was our freshman football coach.
You could find swimmers, who might fit the right mold, and rowing would be a great sport, but the challenge would be for big guys, with limited to no running background being able to handle the training load necessary for the run.
I can relate to you - in fact at 6 foot 5 and 190 I was really discouraged from running. The beauty of triathlon is that its much more forgiving to the bigger guys and gals - we can still compete at a fairly high level because on the bike being big can help on flat courses - and also it tends to be advantage on the swim. Running well - no need to comment - not many big guys that can rip up super fast 10k’s.
I’m surprised that athletes from that ex-big swimmer, ex-rower mould who were very competitive (say national representation level) and have “retired” but still have the competitive urge, haven’t had a crack. There’d be plenty out there and you’d think ironman /KQ would be a bucket list objective for a lot of ex high level single sport athletes. Either seems that’s not the case or being able to run a mara fast is.
Im 6’2’’ about 200-205 and am very competative at shorter races. Did my first full this year, think it would be very tough to be competetive at long course for me personally…then again i wouldnt say im 100% triathlon focused. If someone the same size gave 100% i think they can have huge advantages on the bike…
I am 6’9" and 210lbs and I disagree. I am one of the faster guys at any triathlon, it gives you a huge advantage
Advantage at what…seeing over everyone?
You are good at long course despite you height, not because of it. Above 6’0"-6’2" for males, I think you start falling off the curve in terms of balance between power to weight ratio and power to drag ratios as they impact cycling and running.
6’9" is an outlier in term of just height alone. As an endurance athlete, it’s an extreme outlier to say the least.
If he was 94kg as a Tour de France cyclist (by all accounts) it seems logical that with the upper body growth associated with swim training (and presumably not “ProTour-starving” himself for the sake of AG Tri) Magnus would hit 210 or more.
It was actually 95kg which is close enough to 210lb which is my weight and about the weight of a bunch of my mates and it’s also the “Clydesdale” weight (or one of them). No other reason. It’s a light weight in some elite sports but obviously not in IM
At what distance? I’m 6’3" 225, so not as lean as you. I hold my own in Oly distance racing locally. Even think I’ll do okay at 70.3’s next season. However I think once you get to the full distance things change. At least at my size they did. I’ve only done 1 full to compare though
No offence, but BMI is a completely useless metric, especially so when considering outliers, like people who are very fit, such as in the subject of the OP.
I disagree, BMI comparison to elite athletes will quickly tell you if you are too fat or too muscular for optimal performance. You will then need a mirror to determine which of the two (or both?) you are. At 6’1" 210 lb you are some combination of too fat or too jacked for optimal performance. You just don’t need either to be a good endurance athlete. Not that you can’t perform well at that height/weight… you could perform better.
6’7" have gotten down to 200, could maybe get to 195. tend to be at 210.
Can compete in AG at most races 70.3 and under, once you go full, it is hard.
Goal for 70.3 this year is to get close to 4:30. Even at that I think it is hard to break 10 for full for me. Most smaller guys that can go that fast in the half break 10 fairly easily.
What is the semantical obsession with 210?
Swim training actually leans you down.
The problem with racing as a larger athlete isn’t really the swimming or necessary the cycling but it’s the running, especially running a marathon…
I have KQ’d many times and just last year did so at Ironman France throwing down a 3:12 marathon (to be fair though that would have been a rolldown as that course is not made for someone my size on the bike. 6’5 anywhere from 205-220. Last time in Kona I arrived on the island around 99kg and was at 100kg race day thanks to kona coffee covered macadamia nuts…I think I went 9:21 that year. I’m finding it hard to get under 100kg now that I live in Italy. Also, there is a badass Aussie named Xavier that went 9:05 at about 94kg.
