Knolly Cache Gravel Bike 12 speed eTap
Selling a Knolly Cache Steel size 54 Midnight Blue with Knolly Carbon Fork- Bike is in Next 2 New condition as seen in photos. Excellent quality steel frame that has only has 624 miles on Frame, all components are brand new with Zero miles on. All Removed from 2025 Trek Checkpoint. Brakes will need to be bled. may also need a longer hose for rear brake it reaches but tight.
Loaded with the following
Battery -SRAM eTap battery pack (with charger)
Drivetrain
SRAM Apex, 1x12 speed
SRAM Apex AXS 12 speed
Rear derailleur SRAM Apex XPLR eTap AXS, 44T max cog
SRAM Apex Crank 1, 40T, DUB Wide, 170mm length
Bottom bracket SRAM DUB,
Cassette SRAM XPLR PG-1231, 11-44, 12 speed
Chain SRAM Apex, 12 speed
Wheels
Wheel front Bontrager Paradigm SL TLR rim with CL-712 100x12mm Centerlock Disc hub, 24H, Black spokes and nipples
Wheel rear Bontrager Paradigm SL TLR rim with CL-712 142x12mm Centerlock Disc hub, 24H, Black spokes and nipples
Skewer front Bontrager Switch chamfered thru axle, removable lever
Skewer rear Bontrager Switch chamfered thru axle, removable lever
Tire Bontrager Girona RSL, Tubeless Ready, GR puncture protection, aramid bead, 220 tpi, 700x42mm
Tire part Bontrager TLR sealant, 6oz
Rim strip Bontrager TLR
Seat- Verse Short Comp
Seatpost -Thomson Masterpiece with Thomson Seatclamp
Handlebar -Bontrager Elite Gravel 31.8
Stem -Bontrager Elite
Handlebar tape Bontrager Supertack Perf tape
Brake rotors SRAM Paceline, rounded, centerlock, 160mm
PLEASE LOOK AT ALL PHOTOS CLOSELY, THEY ARE TAKEN TO ENSURE YOU ARE AWARE OF WHAT YOU’RE PURCHASING. I AM NO EXPERT AND DO THE BEST I CAN TO DESCRIBE AND TAKE PICTURES FOR YOU. IF YOU HAVE ANY QUESTIONS PLEASE ASK THANK YOU
