hi. in most tri-fit articles, i’ve seen knee angles listed at about 150 degrees with pedals at essentially 12 and 6 oclock. however, in mr cobb’s slam descriptions, he states that he’s using a knee angle of 45-50 degrees. is this simply the same angle as a 130-135 degree angle with a different reference point (ie, 180 degrees minus 130 degrees= 50) , or is this a different measurement, such as the angle with the pedals at 3 and 9 oclock? thanks,
Hopefully Dan or Tom will see this and give you a more thorough answer but basically you are seeing a difference in style or beliefs of proper fitting.
i’m for 150 degrees or thereabouts (or 30 degrees if you’re looking at the acute angle). and that’s for everybody, steep angled folks included (yes, i’ve changed my view on this).
obviously there’s a range, but no more, i think, than 5 degrees in either direction.
Apples and oranges. I believe Mr. Cobb is referring to the “big slam” position. Essentially a 72 degree angle effective seat angle with the seat lowered a bit below normal. This will automatically increase knee angle compared to a 78-80 degree tri position with the seat set at a normal height.
For the normal tri or road postions most authorities recommend 145-155 degrees. You’ll just have to experiement and see what works best for yourself.
