Keywin Pedals (1)
Has anyone ever tried them? If so what are your thoughts and do you know the stack height?
Thanks,
Rich
They are great, I use the -3mm axles. Great if you need to alter q-factor thanks to the different lengths. Easy to rebuild (so crashing and scuffing them is a cheap fix). Huge platform (I think it may still be the biggest on the market). Engage and disengage are easy - slightly different to look but takes about 1 ride to get used to. Low weight (the cheapies are 248g) and good value (at least they are here in NZ where they are made and they are actually made here).
I measure stack as 18-19mm (centre of axle to top of cleat).
Also should mention that the engagement surfaces are not worn by walking so the performance stays more constant and the cleats last longer.
I’d agree with what cyclenutnz said. Pretty hard to beat for value/performance/weight for the Ti’s. They are cheap in the U.S. - cheaper than NZ for some reason it seems. I have ridden on just about everything and I have been as happy on these as anything. Light and solid platform/connection and you can beat the heck out of the cleats. Only thing: most people don’t know them in the U.S. so you will get comments about your discount-store-lookin’-pedals, which is pretty much what they look like!
been using them for a few years now and love them
Love 'em. Been using them for maybe 4 or 5 years, and I’ve never had an issue. One of the only pedals nowadays where you can actually lock out the float completely, should you choose to. They also have a track adaptor that completely locks the mechanism such that it is impossible to release without first depressing the pin. You can never accidentally pull out. I wouldn’t ride that way on the road, but am considering it for my track bike.
As mentioned above, wear on the cleat interface from walking does not affect the binding mechanism of the pedal, so cleats last damn near forever.
I run keywins or eggbeaters on all my bikes. (Eggbeaters if I plan on walking around).
I knew you were a man of discernment (the post of the paul hubs was the giveaway).
In an effort to be like you I am going to do an iron distance on saturday with 6hrs of riding and around the same running in the last month - is this dumb enough to be tough?
As for the Keywins, moving to them 6-7yrs ago was one of my better buying decisions (going campag is the best)
I’d heard good things about them too & was anxious to try them out for the low stack height & largest platform. Spent $80 getting a pair on line brand new in the box last winter only to discover the cleat wouldn’t fit any shoe. So they sit in my basement. They required some adapter not sold in USA & not available went I contacted Australia folks. I got ripped off on the ones I got. Irked me. I ended up going with the Time RXS & have been happy.
Barb
