I’ve been riding a Kestrel Talon SL for a few years, using it for 2 IM races with bar-end shifters, and without aerobars for group riding in my local cycling club. I really like the Talon, it’s comfortable and rides well. I bought the Talon because I wanted comfort for long triathlons, but I also wanted to do some road cycling. Now that I’m sure I want to stay in triathlon I’m thinking about getting a tri specific bike and I’m leaning toward the Cervelo P2C/P3C. I ride a 48cm Talon and need a short stem to make it work as I have 31.4" inseam and a short reach. I’m guessing that a 48cm P2/3 would be the right size. I wonder if someone could tell me how the handling of these two bikes differ. Will they be that different? I tried to look at the geometries/specs for each bike. Many of the measurements are close but I’m not great at interpreting their meaning. Also, I’ve never ridden with 650C wheels so I have no idea how that affects ride characteristics. Your insights are much appreciated.
When you say “two different bikes” which two are you referring to?
I’ve ridden 650 and I’ve ridden 700. I prefer 700. More rubber on the road, especially when turning. Your seat angle will likely change a lot when you switch from the Talon Sl to either of the two Cervelos. I’d also pay close attention to the head tube height’s of each Cervelo compared to that of the Talon.
The P2/3 is a very different frame design from a talon. P2/3 are meant to be ridden in a forward/low front position with a fair bit of drop from your seat to the bars. If you are riding a 48cm talon with 700c wheels, you probably have very little bar drop if any. At your size, you SHOULD be riding 650c wheels, IMO you can’t make a frame 50cm or smaller fit right w/ 700c wheels, the front will be too high. I wouldn’t worry much about the handling differnce w/ 650c. The bigger difference will be in your body position. If someone can fit you correctly on the P2/3 you should be fine, and you should be faster if you can average over 18mph or so.
The headtube height of the Kestrel Talon SL (48) is 90mm and that of the Cervelo P3C (48) is 110mm. Interesting. I would have thought the Cervelo’s headtube would be shorter, but maybe that’s b/c of the steeper steattube angle?
So why will I be faster on 650 wheels?
No. The HT on the Cervelo is longer because of the 650c wheels. Going from the Talon to the P3C, you are losing 2" in wheel diameter, gaining 20mm in HT height. That’s a nett drop of 30mm.
Ah, is see. Thanks for that info.
