Kestrel Talon sizing help
I’m considering picking up an '08 Talon (road config) at a steep discount, but have no opportunity to try out the two sizes (52 or 55) I’m deciding between. I’ve never been fit for a road bike, but fit nicely on my 54 Cervelo Dual (forward position, 100mm stem). I’m 5’10", normal proportion, looking for the most comfortable fit for non-competitive road riding. My gut tells me the 52 with a 120ish stem will do the job nicely (and that the 55 may leave me with a shorter than desirable stem requirement), but I figured I’d ask the gurus here before pulling the trigger.
FWIW, it won’t be converted to the tri configuration at any point in the foreseeable future.
From Kestrel’s website (apologies for the formatting):
48 52 55 57 60
EFFECTIVE SEAT TUBE HEIGHT 48.0 52.0 55.0 57.0 60.0
EFFECTIVE TOP TUBE LENGTH 51.0 53.3 55.6 57.0 59.5
CHAIN STAY 41.0 41.0 41.0 41.0 41.0
BB DROP 7.1 7.1 7.1 6.8 6.8
FORK OFFSET 4.3 4.3 4.3 4.3 4.3
HEAD TUBE ANGLE 72.7° 73.0° 73.2° 73.5° 74.0°
SEAT TUBE ANGLE 75.2° 74.5° 73.5° 73.0° 72.5°
SEAT ANGLE REAR* 74.0 73.0 72.0 72.0 71.0
SEAT ANGLE FORWARD* 77.0 76.0 75.0 74.0 74.0
WHEEL BASE 96.3 97.4 98.6 99.4 100.8
STAND OVER HEIGHT 74.2 76.5 79.1 81.2 83.9
BB HEIGHT 10.4 10.4 10.4 10.5 10.5
HEAD TUBE LENGTH 9.0 10.2 12.9 14.9 17.6
TRAIL 6.2 5.8 5.6 5.4 5.1
STACK 507.9 521.8 548.4 565.4 593.0
REACH 373.8 387.7 393.4 397.3 408.6
Recommendations?
Get me your body measurements and I’ll help you pick the right frame.
Feel free to call me Monday.
215.824.3854 Ext. 1111
Sharad,
While you are here, I need some help. On my Talon, size 51, I can’t get the seat height low enough cause the aero seatpost flares just a bit wide at the top end. I need to lower my seat height (centre of BB to middle of seat) to 68.3 cm but I am stuck at 68.8 or so. Can I sand down the carbon seatpost so that I can get the final ~0.5cm sunk into the frame, or are there other options without changing my seat.
Or is there a “short bike” seatpost" that allows for more insertion?
Please note that I am riding it as a road bike and don’t need to ride an aero seatpost, so I suppose I can get the adaptor kit for a regular circular seatpost.
Dev
Dev,
We do make a “small” post. You can give me a ring on Monday and I’ll take care of it for you.
Dev…think I may still have the adapter for the round post…if so will bring to IMLP.
Hey Sphere,
I’d be interested in hearing about whatever feedback you received.
John
Thanks Steve. Just noticed your reply. Will call tomorrow. Placidpirate, see you in LP. If you have the adaptor, that is cool. I am staying at Art Devlins. Will get into LP on Friday
I’m 5’ 7.5" and ride a 2006 (IIRC, still from the same mold) 52 cm comfortably- at 1st in road, now in tri configuration. I have shorter arms, kind of long torso, and use a 100mm stem w/ the aero post in fwd position.
You could likely fit decently on one w/ the seatpost in rearward config w/ that 120mm stem as long as your torso isn’t overly long.
Hope that helps.
Not scientific but I ride a 55 and am amybe 1" taller.
Miss ya in the LR! Hope all is well.
Don’t know what kind of price you are getting, but BikesDirect.com has all sizes in stock for $1499. I’m 6’3". I’m thinking that size 57 cm is too small will have to go 60 cm cause I have long torso.
A short post? That’s good to know.
I bought a Talon SL (tri setup) about 2 months back, and the shortest seat post setting was still a bit too high for me on the 55cm (5’11", 30-31" inseam, long torso).
The LBS where I bought it just hacked it down by about an inch.
I think I am on the same boat, interested in getting myself a 2008 Kestrel Talon but not sure whether I should pick a 57cm or 60cm frameset.
Some of my measurements: inseam 88cm, torso 62cm, arm 69cm, 183cm tall.
Any advice would be greatly appreciated.
Thanks,
Rey~
I am 183cm tall and ride a 57. It fits me very well.
I’m 184cm and ride a 57.
Rey,
With those measurements, you are closer to the 57cm then the 60cm.
Let me know if you have any questions.
Thank you very much everyone for your soon reply.
Rey~
Hey Steven,
I am new to the forum and the sport entirely. I am looking to buy a Kestrel Talon from my LBS. I am uncertain of the bike size I need to get. The store only has a 57 available so I don’t know if they are just trying to sell it. Here are my measurements.
Ht 178 cm
inseam 74 cm
Torso 58.5 cm
arm 69
I am about 220 right now but hoping to race in the 180- 190 range. I am just skeptical that the frame might be too big and sub-optimal as far as the seat height is concerned with the tapered seat post as well as the length of the stem.
Thanks
Vic
Vic,
Hard to tell exactly. Your inseam seems short based on your height but I really defer to your local shop since they can measure and fit you on the bike. If you want, you can have the shop call me to confirm your fit information.
you are right. I rechecked and it was actually 84cm inseam. For another reference, the mechanic had me stand over the bike and it cleared ~1 inch off the ground. He said they usually look for around 3. I’m no expert.
I am taking the bike for a longer test ride today. It was the Dura-ace spec’d bike you guys sold at a bike convention in Vegas (2007), apparently.
Thanks
Vic
sharad,
Thrilled to see you on this forum. Looking for sizing guidance myself. Buying first ‘real’ bike and looking for something that can pull both road and triathlon duty. Research has turned me onto the Talon.
I imagine at 189.5cm tall I am automatically one of the larger frame sizes. With ~90cm inseam (wearing my cycling shoes) and ~87cm sleeve length do you recommend the 57 or 60?
All the best!
BJ
