Kestrel inner cable guides
Hey - My LBS swapped the shifters and cables on my kestrel Talon. Does anyone know the correct size/diameter/length/material that should be used? I figure they pulled the cables, housing, and inner cables out and replaced all but the inner cable guides. My bike is noisier and I think thats the problem. Help me, please…
cricket…cricket…
no offense but your post doesn’t make much sense. I don’t think there are inner guides. Just those little brass cable stops where the cable goes into the frame. But then again I’ve only worked on a Talon once and that was a while ago. Fuzzy memory at this point.
Cables shouldn’t rattle inside the frame unless you run the whole cable housing and all through the frame and even then…
