Just put T1 sizing to the test
Just sent Emilio a note asking if he can fit me into a T1 suit. Being as tall and skinny as I am, I am no where near any of the sizes in the fitting charts.
Want to give a 2 piece a try for this season, if I can get one that fits, to see if I can finally get my shoulders freed up.
So, anyone else real tall and skinny and been able to get fitted into a T1 suit? Can they be made custom if needed? :o(
Dave
6’2" 150lbs here, and the T1 is best fitting wetsuit I’ve ever worn
6’5", 175.
So, where you on the size chart? I was not close to anything?
How is the leg length since this is where I would be off the most.
All T1 owners say the fit is perfect. Guess I am willing to spend 500 bucks to find out.
Dave
If it doesn’t fit, send it back. He’ll send you another. They feel quite tight, but are so stretchy that you won’t notice.
I would, but since I am not close to any size on the chart, I will have to see what Emilio suggests.
Dave
I’m short and chunky and it fits me.
36.5 inch measured inseam, and I wear a size 4 top and size 4 bottom
I’d guess size 5 for you, but I’m sure Emilio will give you the best sizing info.
Wow, how tall are ya? Says a size 4 is only up to 5’10.
Seems like the size 5 would be the one to try if I had to pick.
Dave
6’2" 150lbs, 36.5 inseam (yes, all legs), size 4 top and bottom. I’m sure the wrists/ankles ride up an inch or two higher on me than someone shorter, but I don’t view that as a problem on a wetsuit.
i’m 1.88m (= 6.2"??) and 65-68 kg (143-149lbs??) and the t1 fits really well. It’s maybe just a little short at the ankles and wrist (not much), but that doesn’t matter.
$500? You can buy the cheaper bottom half and save some $.
The top straps are pretty stretchy. I think you’ll be able to wear a smaller size that you think. You definitely want to make sure the legs are reasonably tight. If the right fit below has the bib straps too tight, then take it to a tailor or have Emilio add a few inches of material to the top of the bib straps. Hell, it wouldn’t even have to be wetsuit material.
So, I see there are 2 models, the black pearl, and first wave. The first wave is more money.
So, is the black pearl as good as the first wave? If not, whats the difference and is it worth the extra money?
Dave
K, we need pictures to accompany this freak show
The first wave is softer rubber than the black pearl and more flexible. I have a fw top and bp bottom, the top feels softer but its negligable, imo.
I’m 6’3+ 155-160lbs, I wear a 3 top and 4 bottom. Tried 4 of each but the top was too big and switched it ahssle free.
I’m 6’4" and 200 (so a little heavier), but the size 6 top and bottom work well for me. Good luck with the new suit.
Dave
I’m sure that by email or direct phone call, he’ll help you work it out.
I don’t work for him, I just use his stuff.
I got inputs from Emilio on what to get, after he figured out how to get around my dump spam filter. So, will order
a size 4 top and 5 bottom soon. First class timely response!!
Dave
DeSoto wewtsuits, the only different wetsuit on the market, if it fits you will love it!!
Since I got to get an new one, and there is a 14 day return if it does not fit, I sure am going to give it a try!
Dave
Remember to try it and if you have any questions call Emilio, he is one of the only owners that you can get ahold of. Great guy to talk to!
I know this because I worked for him!!
