I just watched Frankie Andreu’s piece on Bobby Julich’s special chainring. From what I gathered, the size of the teeth varies depending on the position in the pedal stroke, emphasizing power in some areas and I’m not sure what in the others. (Sort of biopace-esque)
Can anyone explain this? Also, if these rings do actually work, what are the odds that they’ll be banned by the UCI before next year rolls around?
they have been around for years, and they are UCI legal
note that the UCI does not ban every new item that the peloton uses, case in point - Rotor Cranks have been used in the Vuelta for the past two years, and will be there in force again this year on the TT stages
seems like they produce the exact same advertised benefit as rotorcranks. Rotorcranks are just a heavy, complicated (more moving parts=higher chance of mechanical failure), and expensive way of achieving the same benefit.
"seems like they produce the exact same advertised benefit as rotorcranks. Rotorcranks are just a heavy, complicated (more moving parts=higher chance of mechanical failure), and expensive way of achieving the same benefit. "
They do not work at all like Rotors, as they do not eliminate the dead point, see below:
I saw it on OLN , it seemed just an Elliptic gear cut for the power of the rider , they made a cheap version in the 80s biogear -biomet - ? The builder said it was supposed to even out the flat spot / even power stroke.
*Ovalized cain rings are probably more effective because they accelerate both dead spots evenly and at the same time, at the 12 oclock, and 6oclock. *
********I rode a bio-pace crank a few hundred miles, I think it reduced the pressure at the dead spot, but had a weird feel climbing. but its a soild crank arm / no swing. Its was not right for me as the arms were short 170 mm.
