It’s a Cervelo S2 that I had fitted for a tri position. Any visible problems?
http://www.facebook.com/v/1123486566322 takes a little bit to load.
i’m grabbing some popcorn.
There is a LOT of material to work with regarding decor and cleanliness…wow, what a gem, I had trouble focusing on the rider. On a more serious note - and it might just be the lighting - do you feel like your toes are pointed in too much?
Chances are you’re faster than the average slowtwitcher.
Guilty
I don’t think so? It kind of looks that way though, almost like the knees point in too much?
My Grandpa has that same recliner I think.
Seems generally OK, though your saddle looks a touch low (may just be the angle, the camera is not straight on, and your ankle is hidden by the couch at BDC). It’s a fine position, but you could definitely get more aggressive/aero…looks like an IM position vs. an Oly one.
drop down a spacer?
Put that front wheel level with the rear wheel, so we can see how high you really sit into the wind
Also, why is there a bumble bee out fit on your couch?
That’s my nappin’ blanket.
Seems like you could rotate everything forward, but I’m hesitant to make specific recommendations based on an off-angle video. Try pulling out a spacer (just put it on top of the stem) for a ride or two and see how it feels.
Nice, nice…
Well, from that angle, it doesn’t look aero … but we’ve seen a lot worse…
That said, given your front wheel is lower than your rear, it’s hard to make really valuable comments.
I’ll make a better video and repost after Nats this weekend.
Like I said, it might just be the lighting that makes your feet look pointed in. I don’t believe it will affect how “aero” you are, but it can lead to future knee problems. Just keep an eye on it and if your knees start to feel funky, check on it.
Cockpit is a bit too long, this a cervelo soloist something. it clearly has drop bars and full aero bars.
shorty bar or shorten the stem?
