beston
March 26, 2011, 1:01pm
1
Jtek AeroBrake kit: Includes AeroBrake lever and DoubleContol cable splitter (so that you can still have your regular brake lever too).
this one is for the right shifter.
$45 including shipping to N.A.
http://jtekengineering.com/AeroBrake.htm
http://i557.photobucket.com/albums/ss12/bestonbr/IMG_6767.jpg
Do you know will it work with SRAM R2C shifters?
Thanks.
I’m not positive but I think, given the mounting method (ie: uses the shifter bolt and sleeve), that is should only work with Shimano levers
beston
March 26, 2011, 9:42pm
4
I’m not sure as I’ve never used SRAM shifters. The brake works by replacing one side of the the shifter bolts. I would imagine that SRAM and shimano would be different, but you could always ask Jtek!
http://jtekengineering.com/index.html
