John Cobb's Aerodynamics Explained Video: Look correct, Cervelo wrong?
http://cobbcycling.com/aero-video.cfm
Great stuff. Shows that the rear wheel being close to the seat tube is slow, as Look claimed two years ago.
Sharp trailing edges are slower.
brakes behind the fork are slower. (this was obvioius)
The down tube should be a good distance from the front wheel.
Top tubes without flaring as they approach the seat tube cause vortexes/turbulence down towards the seat tube.
ah, it shows that the wheel being close to the seat tube has similar drag to it being further away in certain situations
It is obvious in this video that John has something to sell. I’m not knocking it just pointing out the obvious. He was obviously hired by javelin to help design their bikes and I’d $100 that javelin paid for and produced this video.
One only has to look at the bike that John personally rides (Willier Cento) to see that he sometimes contradicts himself. Also I think Dan did a review on the same javelin that they are holding in the video and by John’s own testing found that it finished MOP among the top aero bikes out on the market right now. Not bad really for a small boutique builder.
One side note to that article was Dan mentioning the blunt trailing edges of the javelin and how they’ve been used in auto aerodynamics for years. This has since come to our colective recognition as the Kamm Airfoil. Trek has a patent pending on this, so I’m wondering if Javelin/Cobb doing it first might give them rights to keep doing it or may invalidate the patent application. We shall see.
I am not sure I understood some of the nuances, like “you don’t want to bend the air, you want to turn it.”
I heard from someone who has spent a lot of time in wind tunnels with bikes that from the elbows back it is not possible to make reliable general rules when it comes to aero efficiency. For example, he said that he has found that the optimal gap between down tube and rear wheel depends on the riders calf shape and size.
I wonder how many different leg models Cobb used in his testing.
So John Cobb is really Mr. Tibbs, who knew?
People, as in St’rs, need to get away from the general idea that one bike is aero and an other is not. A bike frame is NOT “the most” aero until ALL other factors are added in. This includes the rider and the wheels. Both of these factors are HUGE. Which bike frame is the most aero depends on YOU when added to the bike as well as which wheels you put on it.
I’ve gotten to the point that I’ll buy whatever bike frame I LIKE…then make it the most aero for me, with the correct wheels and my best position.
Then again, when you add all this stuff up in time savings, you’re only talking a few mere seconds in a REAL race.
i believe testing has shown this isn’t usually the case
which testing would that be? the one where … ???
Yes, John rides a Wiler (one ‘L’), but he also helped them design their TT bike (the Crono). Always interesting to see what bike those in the ‘know’ actually ride when they make their own choice based on whatever they think is most important.
Not sure if you’re just kidding due to John’s explanation lacking depth, but in case you honestly don’t get what he’s saying, or if someone else doesn’t, picture it this way. You’re sliding down a slip and slide, great time, it’s sunny, everything is wonderful, but suddenly you look ahead and realize that you have to slide over a 1 foot tall change in the ground. Now there’s two ways you can go over it:
Option A (John’s “bend the air” example)
You hit a 90 degree wall, flip over, crash back, lose a lot of speed and break your nose and then eventually after tumbling over continue down the rest of the slide.
http://i32.tinypic.com/2hrfwv8.jpg
Option B (John’s “turn it” example)
Your friends were very kind and built a ramp up to the difference in height, you slide over it, slow down some, but don’t tumble and overall move across it much faster, even though you had to go a longer time in a raised height (due to the ramp up and down), overall you’re faster.
http://i29.tinypic.com/sfce35.jpg
Now just replace the little guy with air.
Cool Video! Thanks.
But, I’m confused:
“A rider that size (Lessing) would have to overcome seven pounds of force for every square inch.”
Huh? 7lb of force total at 30 mph is 415 Watts. What am I missing?
well i do not agree completely there more to it then just measure the power of a spinning wheel
As an owner of an amazing bike, Wilier Cento Crono, I don’t see where John Cobb contradicts himself. In the video he explained a lot of details of why my bike is designed as it is.
The bikes(Wilier and Javelin) are different, did he get 100% freedom to design the Wilier - and more limitations when working for Javelin?
Good explanation, but I’m still confused. How does air break it’s nose?
It runs into Jens Voight during an attack?
In all seriousness though you bring up a good and often overlooked point. Air doesn’t have a nose, while air does often smell, it actually has no nose of it’s own. So if you want to get as aero as possible, you should remove your nose. Basically that’s the message you should take away from this thread.
various people, over time
only bike that seemed to interact with the rider much was the trimble
Well, the difference between bending and turning is not particularly technical nor obvious. And, according to John, your man would go down the slide faster if the slope was not there on the back side.
Wilier (two "I"s)
:wink:
Steve
