Joe Friel's Cleat Position
See article here: http://www2.trainingbible.com/joesblog/2007/01/cleat-position.html
Advocates moving cleat back to the arch of the foot…discuss…
Mike
My advice would be that if you’re going to move your cleats back, move them back in babysteps. It is a very big adjustment to all of a sudden slam your cleats as far back as possible, and if done all at once, it is a recipe for repetitive use injury.
By moving cleats back, the rider would also need to adjust seat height (down) as well as the fore/aft seat position (forward) as you’re closing the hip angle slightly by moving the cleats.
Ha…same thing my physical therapist said. I do have weak calves. Working on it. Thinking about moving cleats back just a bit as I have some plantar fasciitis issues. Big gear stuff (or climbing) on the bike can be problematic. I am thinking that moving the cleats back may provide some relief. Based on Friel’s experience, I may not lose any power…so might be a good trade off.
Mike
See article here: http://www2.trainingbible.com/.../cleat-position.html
Mike
http://www.ncbi.nlm.nih.gov/entrez/query.fcgi?db=pubmed&cmd=Retrieve&dopt=AbstractPlus&list_uids=16901493&query_hl=10&itool=pubmed_docsum
You’re the doc and this is a respectful question but:
If competitive cyclists are the study group then doesn’t the fact that the numbers are equal imply that an aft position is in fact beneficial on the presumption that the control group are already adapted to riding with a forward cleat position?
and while I’m at it:
Am I right in thinking that this doesn’t speak to the distribution of effort between muscle groups - i.e. the argument that this might save the calves for a run is still possible?
Thanks
What about less trained cyclists, like semi-competitive AG triathletes?
I have found moving my cleats back to be quite helpful in relieving my chronic achilles tendonitis as the strain on the calf/achilles is less with a more rearward cleat position.
I did not notice any difference in power.
There’s always what I call the “anything new” effect. I tend to see no loss, or even a gain, when I change just about anything. Probably just by virtue of using muscles that haven’t been worn out by recent training. This effect usually disappears after a few days.
  • jens
One might also mention that the standard Friel is citing for his “improvement,” IE HR v. Wattage is essentially meaningless…
It’s possible, but I doubt it.
That seems like a more plausible hypothesis to me.
Steve Hogg - a local fit guru in Sydney has been in touch with the guy Joe mentions in his blog. The guy has desgined an awesome shoe - weighs nothing, but you can’t walk in it. I’ve seen the shoe with the bolt holes drilled into the middle of the foot and Steve has had similar increases in efficiency that Joe Friel mentions.
Apparently the guy went bankrupt twice and got divorced after innocently taking the prototype to two very well-known shoe companies to talk about licensing. They both kindly sued him for patent infringement. He won, ultimately, but was broke and single as a result.
Thanks for posting that url Andrew. I was almost ready to experiment and drill holes in my carbon soled cycling shoes.:slight_smile:
Cerveloguy, I tried the experiment 3 years ago and it worked well:
http://forum.slowtwitch.com/gforum.cgi?post=783523;search_string=drill%20holes%20all%20the%20way%20back;#783523
http://forum.slowtwitch.com/gforum.cgi?post=103719;search_string=drill%20holes%20devashish%20paul;#103719
In the end, when I went to Look Keo, I could get the cleat far enough back that it was in the same relative position on my Pearl Izumi shoes compared to Shimano SPD-R Carbon soles with the old SPD-R system with the soles drilled. I’d recommend that it is worth a try.
