Jack Mott and the aero guys, question
Lets call this possible are or slightly mortally wounded. Should I rotate my brake levers to be in line with the baseball?
http://i268.photobucket.com/albums/jj10/Juanmoretime/Cabling/IMG_4170.jpg
What would that do for your braking? Have you ever had a car pull out in front of you during a race?
the latest posts have said that increases resistance
Two things:
-If there is an aero benefit then it probably doesn’t outweight the loss in braking power. Unless you have some seriously strong thumbs.
-It seems to me that it will dirty the air traveling into the base bar and increase drag there.
If you are that concerned about brake drag then look at the vision levers, they SLICE.
http://www.visiontechusa.com/fly.aspx?layout=product&taxid=191&pid=85
I don’t see a baseball…also how do you make something in line with a spherical object?
