It's dull BUT I NEED AN ANSWER ! How do rear computer sensors work?
I’ve just had an ergomo installed very neatly by Planet X. I’m currently putting on the race kit back on it and wondered how a rear sensor located on a chainstay(like those on a cateye or the ergomo) actually works ? It’s obviously a reed switch which is triggered by magnet revolving around but if this detects speed shouldn’t the distance of the sensor along the stay be crucial ?
Any ideas anyone ?
It measures rotations and performs a simple calculation based on the circumference of your wheel (which is usually defaulted to 700 but you can change on setup). Absolute speed (which would be affected by placement) is not measured, although you will probably get a more accurate reading the further out you go.
It just counts/times the wheel rotation and knowing the wheel circumference it can calculate speed and distance, where the sensor is along the chainstay doesn’t matter.
Ah, I see. The ergomo does request a wheel circumference - is 700 inclusive of the tire ?
Doug, whats a good way to identify the circumference of the rear wheel ?
I don’t know the ergomo, but there ought to be a setup menu somewhere to change this. 700mm is the diameter the wheel with an arbitrary tyre on it (I think 23mm)
Sheldon Brown has an article with more than you ever wanted to know about tyre/tire sizing
http://sheldonbrown.com/tire-sizing.html
I told you!
Doug doesn’t know you very well if he thinks Sheldon’s article will tell you more than you want to know about tire width, does he?
I normally measure it by putting a chalk mark on the tyre and ground and the rolling the bike forward until the mark on the tyre is again at the bottom of the wheel and then measuring the distance covered with a tape measure. This will be different for different tyres (even ones of supposedly the same size)
Put a mark on the tire that you can see from the side. Roll the bike along a straight line and measure the linear distance between the two points where the mark on the tire touches the line.
Well it told me more than I ever wanted to know :smiley:
Thanks Doug. I looked at that but it doesn’t cover circumference. The chalk idea sounds feasible although i threw most of mine at students before white boards took over…
Ah, Doug. No-one reaches the heights of geekdom that Stato (Bryce) does. Consider yourself normal but never average…
There’s a chart here http://www.branfordbike.com/computer/comp10.html
This covers approx circumference for different wheel/tyre size, but I find that it varies a bit between different manufacturers so its best to measure it directly.
Thanks Doug. Very useful.
You get the same reading no matter where on the spoke the magnet/sensor are located.
Unless there is an extremely large amount of centrifigal (sp) force on the wheel as it’s spinning - way beyond what I’d imagine any human could generate - physics dictate the no matter where you are on the spoke it has to cover the same distance as any other point on the spoke in the same period of time.
This same principle is what makes airplanes fly.
Now if you get into the world of say computers, you will actually get faster data reads towards the outside edges of a DVD/CD because the density of data is the same at all points on the disc, but because the outside edges are traveling “faster” you are able to read more data bits in the same amount of time.
"This same principle is what makes airplanes fly. "
I don’t think that analogy is completely apt, but I see where you’re going. Strictly stated Bernoulli’s Theorem is really about conservation of energy (Ptotal = Pstatic + Pdynamic) along an airflow, as opposed to rotational laws of motion. FYI, that is the first use I’ve gotten out of my Aerospace Engineering undergrad in a very long time :wink:
“Now if you get into the world of say computers, you will actually get faster data reads towards the outside edges of a DVD/CD because the density of data is the same at all points on the disc, but because the outside edges are traveling “faster” you are able to read more data bits in the same amount of time.”
This is what I was really getting at. The limitations of the sensors (and not physcis) are what make the in close measurement less precise. This is really an intuitive thing, but as radius approaches I would expect that the measurements would become less precise, although I would bet that any reasonable distance away from center would give you a decent reading.
I love all the geeks on ST! Geeks of the world unite :slight_smile:
Keith
A few things…
  1. Mounting the magnet closer to the hub than the rim usually improves performance. It will be traveling slower (and give the sensor more time to react) the further in it’s mounted. But, anything side 3/4 of the way to the rim is usually fine in my limited experience.
  2. The rollout test described above is not very accurate. There are many things that affect the rollout distance, including tire pressure, bike/rider weight, tire make/model, etc. To do a useful rollout test, I’d suggest getting a helper and doing the rollout measurement with the rider on the bike and the bike “dressed” as it would be in a situation where you’d like to have the most accurate speed (correct tire pressure, number of water bottles, etc.) (I’m probably being a little too anal here, but…) Make sure you ride/measure in a straight line! And, for the most accuracy, count a number of wheel revolutions and then divide to get an average to reduce the variables (wobbling, etc.) I usually do this by scooting along a wall with me wife watching the mark on the tire go around and marking the start/end points on the ground. (And, yes, she loves doing such things!)
Steve
For a 700c wheel, this is the formula I use to calculate the wheel circumference. All measurements in mm.
Circumference =pi*(622+((tireheight-3)*2))
622mm is the bead diameter of a 700c clincher.
the -3 is to allow for compression of the tire when bearing weight. Alternatively, you could measure the tire height when someone is seated on the bike, but I find that my method works pretty well.
i think that you should always underestimate the number. I think a standard 700c wheels is about 2020mm or thereabouts. I tend to set mine to 2000, so that my speedo reads lower than i’m actually pushing. It works great for training. Then correct it on race day.
700c clinchers are about 2096 IRC.
Tubies are significantly less.
