It's cold out. Some energy tips
This comes from our friends at Progress Energy
Keep your thermostat at the lowest comfortable temperature between 68 and 70 degrees. Every degree above 70 costs an additional 7 percent to 10 percent. For example, keeping your home at 75 degrees could run up your heat bill by 47 percent compared to keeping it at 70.
Lower your thermostat at night or when you leave the house. Progress Energy recommends setting the temperature at 70 degrees Fahrenheit during the day and 60 to 65 at night.
Keep doors and windows closed when heat is on.
If your fireplace is not in use, make sure the flue is closed. Glass doors also help prevent heat loss.
Using a portable heater for “spot” heating lets you lower the temperature in the rest of the house. However, it can be costly running it 24 hours a day.
If you have a heat pump, adjust your thermostat in small increments to avoid the operation of the supplemental heat strip in your system. Energy consumption is much higher when the heat strip is in use.
Keep the outside unit clean, clear and unblocked.
Be sure the filters in your heating system are clean.
Caulk and weather-strip any leaky windows and doors.
Open drapes and shades to help warm the home during the day. Close them at night.
Make sure drapes and furniture are not blocking air registers or returns.
Keep the fan on your central heating unit on “auto” position. Leaving the fan on “on” can add $25 a month to your heating costs.
Don’t close off more than 10 percent of the unused rooms in your home. Your heat pump works best with free airflow throughout the house.
Source: Progress Energy
We have been having lows in the -5 range and highs in the single digits. I keep my thermostat at 66 when we are home, 62 when asleep, 60 when off at work. Furnace still runs a lot…(seeing dollar signs flying by…), I can’t imagine having it at 75 degrees…
Today we got 6.5" snow…
So much for global warming!
We keep our thermostat programmed at 68 from 6-8 am, and 6-10 pm. The other hours are all at 62. Since I’m home during the day I just wear more clothes if I get cold.
We also keep our blinds/curtains closed to keep heat from escaping through our double-pane windows. In areas where the heat vents are closed we also close the door to keep from having to heat these areas with heat from other rooms, thereby negating the effect of closing the vents.
