So I’ve had ITBS in the past and know exactly what it feels like and where the friction occurs on the outside of the knee. After my long run on saturday I noticed that me knee was a little stiff. So it feels a lot like ITBS in that it has that “catch point” where it feels a little tight. It hurts a little after the first few miles and gets better after I stop. The problem is that it is slightly…and I’m not a doc…more “inside the knee” towards the kneecap but not under/above/below the actual kneecap…just about halfway between the kneecap and where I would expect IT problems to occur. It just feels like a rubber band that is a little too tight. It doesn’t hurt but I can definitely tell something is up. So, sorry about the vague description, but what the hell is wrong with me NOW???
Hey Jamie, I had the same thing. It is still IT band. When it gets down closer to the inception point like that is more than likely coming from your outer hamstring area. I went to Kathy Shadrick to get it isolated and stretched. She fixed it, but nothing else worked, including several sports medicine visits. Her info is on the CCMC site.
rip
Hi Jamie,
Yep, I’m fighting the same thing here. My lwr back gets tight, then my hip on the same side, and before you know it my knee hurts and my shin hurts. I plan on getting massaged at least x1/mo now and if I can afford it maybe twice/mo. Go for the massage, also do some yoga/stretching as tolerated. If you don’t already have them, I highly recommend the foam roller and TP massage ball for self massage. Also, the RW site and runningtimes has some great stretches for the ITB.
N~
Rip,
Thanks. I scheduled a massage after work today and I’ve been stretching the crap out of the thing. It really does feel like the IT but the position of it just seems wrong to me. I know you can get it in the outside of the knee and the hip but this seems kinda wierd so I thought I would see what ST’ers had to say.
Yeah, you are right it does go down into the shin as well after running for a while. Are you assuming IT too?
I know, it seems weird, but have them really work over your lower/outer hamstrings. You should give Kathy a call, it could be coming from a variety of places including pierformis (sp), medial glute, soaz compensation…
I would never have figured it out without Kathy. And she is not outrageously priced.
Rip,
Where is Kathy’s info on CCMS site. I can’t find it at first pass.
Go to coaches corner, and see article on injury prevention. Her number is 587-1515.
rip,
watch for a pm in a minute
Yep, it does sound like IT probs on your end. My R leg was a big mess, still sort a is. I’m changing my shoes out starting today and seeing if that might help some. Get a good massage. I’m sure she will be able to tell you whether or not it stems from the IT or somewhere else, just depending on where your tightness is.
N~
