I know the old common knowledge was pain in the back of the knee=seat too high and pain in the front of the knee=seat too low?
Is this advice worth giving a shot for an easy ride to see if discomfort might be relieved? I have a little IT Band/front of the knee pain. Not so much pain, just annoying and uncomfortable. Should I try raising my saddle? Moving it forward or back? How much?
probably raise it. go for a bike fit, my position was aggravating my IT pain for over a year, and the position change cleared it up QUICK. Spend the $150 or whatever for a good fit from a legit place.
I am no expert just relaying what I was told. Recently I moved the seat forward a fraction (it was a temporary adjustment until my replacement saddle came in). A cycling coach and fit expert told me to be careful with moving it too far forward as it would result in exactly the pain you are describing.
Definitely a professional fit is a good investment but you could make slight adjustments and see if the pain goes away.
Thanks, what’s the recommendation when raising the saddle? 1/8" at a time? 1/4" at a time?
I did have a good fit done at the beginning of this season and will probably go back and get reevaluated in the off-season. I am very comfortable in the aerobars. Since my fit though I know my bike fitness has come way up (not sure how that effects things if at all) and I have also probably over-cooked the run training a little.
So for right now I am going to back off on the running a little but was wondering if a bike position adjustment might help as well.
So maybe instead of raising it I should slide it back a little (which would also give it a relatively small effective raise). I believe when you slide the saddle forward you are suppose to raise it a little and when you slide it back lower it a little. So if I slide it back but don’t lower it, it should be a small effective raise and maybe some relief from the move backwards as well.
Before you adjust anything see how tight your hamstrings are. If they are really tight spend a few days really working on stretching them and see if that gets rid of the front of knee pain on the bike. This happened to me and it took a long time to figure out but my hamstrings were so tight they were causing front of knee pain on the bike.
I’d second the stretching. I increased volume a bit too fast, and my left knee gave me some low-grade aggravation for awhile. It felt better whenever I stretched, and finally just went away- took about 4 weeks. Stretch really well post-exercise and warm it up slowly, and that may do the trick.
Did you make any height adjustment? Theoretically when going back you are supposed to lower the saddle a little as well.
I am thinking of sliding the saddle back, maybe even a touch more than you suggested as it is pretty far forward and I ride on the nose. But I think I may leave the height as is.
I have similar situation, my right hammy is very tight, I am stretching 3X day and icing knee and hammy but it only gets worse, I have not been doing any strong workouts, just short runs on treadmill and short, high cadence bike rides. Should I be thinking of adjusting my seat back as I read above to help on top of the stretching and ice?
Before you do anything else…please get professionally fitted. I can refer you to somebody in altlanta (are you near)? I have it band issues and I don’t recall an association of the frontal pain you are describing. Yes, when it syndrome gets severe it can pull the kneecap though. Sounds like you need to find more of a pull with your hamstrings. When I am cycling and I feel the pain in the front…it is usually b/c I am using my quads too much. Try more pulling with the hams.
