Issues with Sram TT-900 shifter(rear)
I was wondering if anyone have experienced any issue with the rear sram TT900 shifter, basically my shifter locked and i only have 5 gears(smaller cogs).
If you had an similar issue , were you able to get fixed ?
Thanks
What cassette are you using? I was running an Ultegra with mine and found some info on-line about using a SRAM specific cassette because of a ratio difference in shifting. My bro-n-law (ex-bike mechanic) backed it up, and after switching out the cassette and making some adjustments I was running smooth again with the entire gear range. I’m not a bike mechanic so some of this language is foreign to me. SRAM’s on-line instructions are well written and pretty easy to understand. Good luck! -j
Jhornebx,
I use full Sram components, but on the bright side of things i took the whole thing apart and put back together and the TT shifter is giving me the motion of all 10spd, inside of the TT shifter there are four little parts that look like a puzzle, and i it looked like it got out of place making it blocked and not allowing the to shift properly.
