I’m trying to determine what the average output would be required for a 160lbs (72.5Kg) rider to ride the IMAZ bike course at 21.5MPH. Since I’m just looking for a ‘back-of-the-envelope’ calculation, I went with a frontal area of .41 and standard drag.
Is there a quick/simple formula for caclulating this? I ran the modeler on analytical cycling but came up with a 338w number - so, clearly, I screwed something up.
did you set the slope to zero on the calculator? You may want to set your FA a bit higher (or the drag coeff) as .41 x 0.5 gives you an unrealistic (for most triathletes) drag.
I can give you a ballpark. 21.5mph would give a 5:13 bike split. Assuming your aerodynamics are decent (some sort of race wheels, decent fairly low position), I’ll say about 245W as read out on an Ergomo, which would be about 225W on a Power Tap. If it is a high wind day or they add more turns to the course, it will take more than that. At my 190lbs, 250W on my Ergomo would put me in at about 5:20 or so. I ride the course all the time. As a point of reference, it takes me about 315W to make 25mph as aero as I can get.
The CdA value of .41 is pretty bad. Try values between .25 and .30 to start, but without really knowing your CdA, your just guessing. .25 would be a good aggresive setup, wher .30 would be a bit more conservative, but still assuming you spent all your time in the aerobars.
the number you stat are very high and as paulo says, it s hard to compare value because of so many variable. To ride a 5:15 with 250 watts…i would need a paracute behind me and MTB tire rubbing on the frame.
for me, 240ish was 4:52 in hawaii riding alone all the way. At anything around 300watts…and a good position, you should be leading any ironman races.
What would you say to the fact I had an athlete go 4:48h in IMAZ on 226w avg? And no, he doesn’t weigh 80lbs.
This is just a friendly reminder that you can’t compare watt numbers like that.
What shaner says is closer to the truth, the Cd number the OP picked up is a bit on the high side. But using ac.com is the right tool to use here.
I’ve gone 4h48 at roth on 209w, and I weight 140lb
209 watts for 4:48 do you have a picture of your position? post it!!! and one question to settle this argument… is the course short and is it true the drafting is terrible on that course???
That sounds about right, for an athlete that pays proper attention to position and setup. OTH – I know a guy who rode 5:35 on 225w.
If you search for pics of #298 in roth 2006 you will find me.
the course was 2km short by my SRM, but it has a fair amount of climbing.
drafting, the problem is two many people in a two loop course, the first lap was fine, in the second, with the relay cyclists in, it was a nightmare for 30-40km, until we reached Greding, the main climb, and people got spread appart.
I would say you had just about the leanest pro triathlete out there which tends to lead to a very good aerodynamic profile. I’d bet he also rides a pretty hot bike setup with an aero helmet. low riding position, and stays aero 99% of the time. How many watts do you think a pro like that “steals” from an age grouper of the same weight…my guess is 15W more for an average bodied age grouper with the average bike setup to hit the same time. Also last year we had weird winds…I was doing great time/Watts on the first two laps but the 3rd lap seemed slower.
I ride IM with about a 7cm drop seat/pads. 226W as reported on my (often calibrated) ergomo would put me in right around 5:40 or so. I’ve got wide shoulders and big arms and legs, so even with a stupid low front end, flat back, and aero helmet it takes 315W for me to average 25mph. That’s at 190lbs and not much fat by US standards. A 160lb guy who’s 5’9 and solid in the upper body is likely to be slower for the same watts than a 160lb guy who is 6’2".
As you say, you watts needed vary by person. I remember seeing some numbers from Fernanda Keller at Hawaii a couple years back at like 170W - I wonder what Natasha averages. But I have never found AC to give me very good estimates for speed on flat or windy courses…it a lot better for speed up an incline in my experience. It’s too hard to guess an accurate enough Cd.
It could be that my Ergomo just reads real high. As I mentioned, it makes a difference what power meter you are talking. But I probaby have about as many CycingPeaks entries of the IMAZ course as anyone, so I’ve got data to back up my estimates. 226W for 4:48 on a guy with a pro setup that weighs maybe in the 140’s would be in line with my expectations assuming a power meter that reads out somewhat lower than mine - lots of variables.
