Is there a siginificant difference between the p5x case and the biknd helium v4?
So anyone know for sure if there any difference other then color?
Thanks,
Jeroen
Hi,
The only similar parts are the rear axle mounts and the airbags. Everything else is custom for the P5X.
Here is a list of the custom parts
Molded Bottom Bracket mount with integrated v shape (different height to normal case)
Molded Seat tube insert ( the seat post is attached on the top of this)
Seat cover
Higher front axle mount with cross brace
Seat cover tube sleeve that is used to hang the seat in between the rear triangle
Handlebar-fork left and right sleeve. The aero bars are attached using these sleeves that go through the fork.
Tool case plus tools
Crank cover with rear extension
Wheel covers
etc etc
regards
Biknd
Thanks!
