Is the PowerTap HR Chest Strap Waterproof?
I have never worn my HR strap during a race - but I want to for “data collection purposes”.
Is it waterproof? Can I wear it under my race jersey and wetsuit and will it survive?
I’ve worn the 2.4 coded strap under my wetsuit many times without ill effects to the strap.
Chris
I have swam with mine probably 40+ times (at distances from Oly to IM) with no problem other than it sometimes slips down around my waist if I don’t have a wetsuit on, so you have to pull it back up coming into T1.
Yes, but cycling in the pool is not going to make you faster.
Chris
Same here but recently my HR data was freaking out…checking the battery cover I saw the thin O ring that seals it was a bit munged up and was letting water/sweat leak in eventually nuking the strap. However Saris was VERY helpful with either sending me the O ring/battery cover replacement parts and evenutally a whole new strap free of charge since I was under warranty for it.
So just take care when replacing the battery and putting the cover back on.
cheers
S.
