I managed to hit something or other in the road today. Whatever it was must have kicked up into the spokes. It jammed somehow, and proceeded to rip my rear derailleur right off the bike. It bent the aluminum piece containing the rear dropout and the threaded attachment point for the derailleur.
I have a carbon frame bike. The threads for the derailleur attachment are damaged, but I can’t tell if they are beyond repair.
Presumably, it can be repaired, but this frame would only sell for maybe $500 on eBay. I have one of the old Trek Y frames, which I dearly love. I would hate to see it die an early death.
Anyone in the market for a shreded 10 speed Chorus rear derailleur?
You can fix your frame. The solution is to fabricate an aluminum “seat collar” that clamps around the mast and keeps the expansion plug from spreading the crack. I have had to fix other bikes this way for the same problem.
Form a sheet of aluminum stock to match the curve/profile of the mast. Sheet should be wide enough to cover the entire crack, plus approx. 1 c below. Extend the formed sheet far enough past the trailing edge of the mast to provide enough space to tap/drill out for fasteners.
A formed sheet will work, but I have, in the past, machined an AL collar from billet to match the mast profile perfectly - worked great, and probably doesn’t dgrade aero-ness all that much. Looks cool too.
I can put you in touch with a machinist who can do this for you if you need a referral. Better than tossing the frame, that’s for sure…
If there is enough material left on your dropout, a skilled machinist/frame builder can modify the remainder of said dropout to attach a replacable derailleur hanger. The cannondale hangers are very good for this mod/repair. I have fixed a couple of Treks this way myself, and have seen many, many more go through a friend’s shop.
Let me know if you need a repair referral. If you put a pic up, I can probably tell you if you have enough dropout left to fix.
As long as Trek still has the dropouts for Y-foil frames they can fix it. I did a simmilar thing to a 5200 frame a few years ago. Trek heats up the dropout to melt the glue that holds it in the tubes and then they glue in a new dropout. They didn’t even damage the paint and I think that they charged me about $50. Your local Trek dealer will be able to make all of the repair arrangments.
THIS is why I only race and train on $99 Huffys. I’d have to slit my wrists if I had one of them $5000 super aero speed machines and had what happened to aj’s ride happen to mine.
I kind of think of my bikes as “limited use disposables”, anyway. ;-))
Yes, Trek can replace the dropout on your frame, for a nominal fee - but why would you want to do that? It’s just going to break again.
An aluminum dropout that is not user-serviceable is ridiculous, especially one like that used by Trek, which has a long history of failure. I have seen at least a dozen of their dropouts fail, including 2 as a result of the bike falling to the ground from a leaning position.
These bikes should have replacable dropouts, period. Trek makes some of the finest carbon fiber frames on the planet, but their dropout design blows.
here’s contact info for a frame builder I know personally to have fixed a bunch of these…
