You phrased your question incorrectly to get maximum ST response.
To get maximum response - you need to tell YOUR watts/kilo…then you get a flood of people
telling you that you’re pathetic and doing it all wrong. They still won’t tell you their own numbers…but
at least you get a lot of responses
FWIW I have ridden at about 2.5 W/k in two races - and both times had a top 20% finish in 40-45. To place
higher, I guess you need more…
+1
And, it really helps if the post’er states their weight since a 30lb difference in body weights can produce one helluva different W/KG #.
Also, most, but not all ST’ers are smart enough to answer this post with their WKG for the 112 miles, but then there are those people who will post up their 1HR W/KG thinking that is the ONLY WKG (like MAP).
I was having a conversation yesterday on the whole W/KG subject with a rider who stated that he’d bumped up his W/KG to 4.1 on a ride over the weekend. I asked him to send me his file and when I dropped it into WKO I noticed that he’d set the chart to sample for 60 seconds, but assumed he was looking at a figure that represented 1 HOUR. DOH!!!
Anyway, poor guy was pretty bummed, but it shows that WKG really isnt a good marker for Triathletes since CDA and NP would be much more telling for either a full dist IM, or an HIM. A 3.75 WKG for a 150lb/68KG rider would be 255 watts for 112 miles, and that’s a pretty stout number to hold for 4+ hours. For someone who’s perhaps a Clydesdale that’s dropping 20lbs to say 190lbs/86KG, a 3.75W/KG would be 322.5 watts for 4+ hrs. For my CDA (which I do have) That’d have me averaging 27mph on flat ground/no head or tailwind, and that’s just not gonna happen.
At the VineMan HIM last year I dropped an easy bike split of 2:37 with lazy 209/225 avg/np at 214lbs/97kg. So that’s a WKG of 2.15 which is very very laid back for an HIM.
For IM this year, I have dropped down to 85kg and will be looking for a W/kg of 2.2, and if I can keep my VI down then I should have an NP that is only 12 watts higher.
So, if you stayed with all that nonsense above, then great…but wouldnt it all be a LOT simpler if we just skipped the WKG foolishness, and just went with NP and dist. ?
