Try again, maybe? I got a sold out message, but went in again and got registered.
Yes it finally came through.
I was scared for a moment.
I had the opposite reaction. I was scared when my registration went through.
Coming back to the course, is this an Aussie exit or are we doing 2 loops in the water?
I believe you exit run over timing wire and then dive in. That way there are no one loop heros who fake they have done two loops
An Aussie exit would be fun, but even if we donââŹâ˘t hit the beach, the water is very shallow near the shore so it would be dolphin diving for the entire turn around.
I am in! Excited.
Also did Ironman finally cut active.com out of the registration loop? I registered entirely within their site, and it worked pretty well except for the stripe integration part - it was flaky as always. Progress!
Good to hear - I always wonder how many people get caught/donât get caught on 2 loop swims.
Iâm curious if thereâs going to be congestion on loop 2 given how close it looks to the shore.
If the swim typically ranges from 1h-2h for most people, and it takes 30 mins for everyone to file through, then it might get tricky on the back half.
One of the things I find odd with the run course is that we only do Wellington 1x. Per the course description we do Wellington, then hit the canal, and then donât do Wellington again for the 2nd loop. They could easily turn around sooner at Dowâs lake (or even just skip it and turn around at Bronson), or turn around sooner on Col. By.
It seems to me that if youâre looking to show off Parliament, Supreme Court, etc, youâd do it for both loops since you need it closed for most of the race anyway.
The only thing I can think of is that if you only have it for 1 loop, you can re-open that section sooner - but I donât think theyâre closing Portage anyway.
It looks to me that you will in fact run that section twice. The first time is starting your loop 1 (a short out and back, i.e. km 0 to 3), and the second time is finishing the run (the same out-and-back, km 39-42.2).
That section of road will need to be closed until midnight, but the Portage bridge would not need to close (it wouldnât be accessible from westbound Wellington).
Placid is two loop swim and personally I did not noticed any issues.
the thing about the course mapping, maybe at this stage theyâre just showing the idea of the course and as time progresses theyâll sort out the specifics, bc totally having both run loops in front of parliament would be awesome⌠iâm pretty sure they have openly noted they arenât sure of T2 or the finish line locationsâŚ
I think youâre right that we do it twice, but the image is confusing.
Thereâs both a 2km and a 40km marker on Wellington (near Bank?), which would mean we definitely do it twice. But there isnât enough distance between there an the finish line unless the 40km marker should really be on the north side of Wellington - signifying we pass Parliament and then head out for our final few kms.
Seems odd that you wouldnât just do 2x of the same loop - thatâs going to be confusing when everyoneâs at their lowest mental capacity.
My interpretation was we do 2x20km loops and then do the 1km Wellington out and back ONCE at the end of second loop after bike course is effectively closed for most people (bike course typically closes at 5:30 pm which is 10:30 into the race, so you donât have hoards of people on the run out and back until all the cyclists are off there).
I personally think that the grind up and down wellington from 40-42 km will be a massive slog that athletes wonât really like, but letâs see.
In any case, in keeping with the theme of my brain writing cheques that my body canât cash, I signed up to secure a spot. Now I have to ignore that I signed up and just train for swimming and olympic tri like I do (10km runs, 1 hrs trainer rides etc), and then see if my ânormal planâ of scaling to half IM length rides in the summer and some 15km runs can scale to more like 4.5 hrs rides and 2 hrs runs for 3 months in 2025 and I get to the start line to finish my first one of these fulls in a decade. Its probably not the brightest idea given everything going on in my lifeâŚworst case I pull the plug using Flex90 or downgrade to a half IM next summer.
Hell, I havenââŹâ˘t laced them up since Timberman 14 years ago, 35lbs ago, and two kids ago and IââŹâ˘m thinking about it with the bike goin right by my front door and the run a 10 min bike ride away !!
Ok, I just thought about it and iââŹâ˘m good to just watch and cheer âŚ
I am in! Excited.
Welcome to Ottawa. You will enjoy the trip
Dev, I think when you head back via Queen Elizabeth you take Pretoria over to Colonel By for the second upper loop, then back downtown the next time for the finish (look at km 20 then 22 on the map)
When leaving transition for the run just before the 2km mark, the first runners will be crossing the last loop bikes who will be turning left onto Lyon. Maybe a foot bridge there?
Question for the locals: is the bike course suitable for a group to come up and do a pre-ride this August? I saw in a post earlier that certain sections are even closed to cars on weekends, is that right? This assumes weââŹâ˘re not a-holes and ride single file, etc.
These are the parts they have closed to cars on weekends:
https://ncc-ccn.gc.ca/events/weekend-bikedays
Thanks!
Yes, a good chunk of the course is closed to cars on Sundays up until either 4 or 8pm, depending on the road. Thereâs a section in the middle where youâll need to take the Multi-Use Path (MUP) along the river/canal to get between the parkways, but most of the kms of the course are closed to traffic. The exception is Col By parkway on the east side of the canal, and the parts downtown. If you take the MUPs as a go between, I believe that you can do the route without traffic (though its been a while since Iâve done the Rockliffe part so someone please correct me if Iâm wrong).
The only catch is that the parkways are generally well used by families and non-athletes out for a Sunday ride. The stronger cyclists tend to move to the much more hillier Gatineau side. I tend feel awkward blasting through at any kind of speed if its busy. I wouldnât do it at race pace, but if youâre looking to recon the course and youâre courteous to those also using the parkway, then its good to get in a course recon.
If you really want to scope out Col By, thereâs a MUP parallel to the route - but this might be better as a run recon (itâs on the run route too) - it can also get busy with lots of walkers and runners.
More info: https://ncc-ccn.gc.ca/events/weekend-bikedays
ETA: One thing I should note is that the route marked as âSir John A MacDonald Parkwayâ in the Ironman route is the same thing as the Kichi Zibi Mikan in the NCC site. Ironman is just using the old name.
