Does anyone have any information about the swim at Ironman Arizona? Is the “Salt River” salty? Does it have a current? What is the average temp in early April? Wetsuits? Full? Is it deep, shallow, muddy or clear. Any thoughts you might have would be appreciated.
I have been in it a few times. It is not salty, it is water from the Colorado River that has been canaled out to Tempe. It is a little murky, not muddy though. No bad taste or anything. It is warmish since it is not naturally flowing and does not have a current. Nothing to worry about, it should be flat and fast. Maybe a little sun in your eyes as you head east in the morning.
It will be a wetsuit swim. Not sure what the water temp will be, but it has been sufficently cold in early May for the Olympic distance races (which 3D has apparently decided not to do anymore). I’d guess below 70, plan for a full suit if you can.
EDIT: I apologize for the is post. In the “Replay” box, it came up as a pretty table. But that got stripped out and this long run on thing came up. I will try and reformat it a bit.
I was also told that the air temperatures vary widely and can zoom up fast from early morning numbers. You may need to build some flexibility into your clothing program. pArticularly if you think you may be running after dark–you may have to have a plan for getting a layer back on, if you have dumped it off in the morning.
Here is some historical date for April 6 through April 11.
Temperature
Average High Temperature is 75 F historical range 55 F to 90 F
Average Low Temperature is 54 F historical range 42 F to 70 F
There is a 2% chance of a Hot Day (temperature over 90°F) (1 day out of 42 in historical record).
There is a 98% chance of a Warm Day (temperature over 60°F) (41 days out of 42 in historical record).
There is a 0% chance of a Freezing Day (temperature below 32°F) (0 days out of 42 in historical record).
Daily Precipitation
Average Daily Precipitation is 0.02
There is a 5% chance of a Precipitation Day (2 days out of 42 in historical record).
Cloud Cover
Average Cloud Cover is **mostly sunny **
There is a 7% chance of a Cloudy Day (3 days out of 42 in historical record).
Wind
Average Wind is 4 mph historical range 0 mph to 13 mph
There is a 5% chance of a Windy Day (average wind over 10 mph)
Humidity
Average High Dew Point is 39 F historical range 22 F to 53 F
Average Low Dew Point is 24 F historical range 5 F to 43
here is a 0% chance of a Humid Day (dew point over 65°F) (0 days out of 42 in historical record).
I hope so too. I received an email update from them in the last week or so, and it wasn’t listed. That was at my work email so I can’t check. I guess I can email Kenny and find out for sure.
Wow seems like you did some research. I was curious because I forgot. Are you planning to do IMAZ next year also after IMF. I know Herbert will be there I think.
