Ironman Advice Needed RE: Waterbottles
I have absolutely no intention of debating what is or is not the most aerodynamic water bottle configuration for the bike. My question has to do with mixing powdered drink mixes while riding. I have recently begun using Infinit for my source of calories and love it, but was curious as to how people restocked on the bike. Do you carry the powder and mix it into the water bottles you receive on course? If so, how do you carry the powder? Does anyone mix it into an aero drink bottle? If so, how do you get it to mix while riding? Any explanations and help would be greatly appreciated. I want to start practicing in training so I can get used to it come race time. Thanks in advance for any help.
i’ve done this in three IMs, with gatorade, when another drink was on offer. obviously, i thought the offer terrible. i usually think i can just drink whatever they give and down it because i need to and i won’t die, etc., etc. in the IM i thought i’d hold back drinking enough due to foul taste, so went with my own gatorade powder.
here’s how i did it, generally and the changes.
1). use sandwich baggies (no zipper) with the right amount of powder for 3 cups of liquid gatorade (tall water bottle or front open-top profile-type bottle). these i close with a rubberband wound around. i carriy these in my jersey pocket.
2). i have a behind the seat bottle holder and put water bottles there from aid stations. when i need to refill the gatorade i pull out the baggie, make a hole in the bottom, (usually with my incisors), push the plastic netting down with my thumb and let the powder fall in, shake it if i can and wait for it to get down at least somewhat. this is a VERY imprecise action. it takes practice. i put the empty baggie in my pocket. then i reach back for the water and start squirting it in the front bottle.
3). this is a hassle. if you can tolerate the stuff on course, do it.
in your case, the stuff seems to be your main means of calories, which mine isn’t. i do ensure+, which is in a water bottle on my downtube. however, the process would be about the same, i think. i tried putting the water in first, then adding the powder and it was not a happy venture. i naturally almost fell over, and also the bottle was too full and the powder wouldn’t drop. let’s just say i did not feel smart…
peggy
Thank you. That is about what I figured that I would have to do. I think Gatorade mixes a little easier than Infinit does though. I just didn’t want to premix and have to carry a bunch of bottles with me on the bike. Plus the fluids would probably get pretty warm that way as I am planning on doing IMAZ. I will have to give the baggie thing a try on a couple of my training rides. Thanks for the help.
There are generally two school of camps for INFINIT users. A portion will super concentrate their nutritional needs into two water bottles-INFINIT dissolves readily, you can fit approx 1200 calories per bottle. Others will take three bottles for the first half and then pick up another 3 at special needs. Both work!
I am personally not a fan of mixing on the course. If you are going to super concentrate-usually people will dial the flavour down a bit. Also make certain that you chase it with the appropriate amount of water. You want to get it back to the concentration that it was intended once in your gut, so it easily absorbed-you do not want to have to digest and of course you have to ensure you have the right amount of fluids.
Thanks. That might be a better idea than trying to carry powder and mix on the course. I have always heard the warnings about not getting your special needs back though. Well, at least I don’t have a sensitive stomach and could just ingest what is on the course. It would be great if Infinit was there. :slight_smile: Thanks for the advice. It is good to get the ideas from the people whose product you are using. Thanks for the support.
I have done what imtri-ing mentioned with infinit for IMAZ and IMFL and it worked great both times. I carry 3 on the bike premixed and pick 3 up at special needs. I toss the used bottle at an aid station so I get lighter as I go. I mix the calories to drink 1 bottle an hour. For me 2 and 1/2 scoops of the Mark Allen Energizer formula gives me the right amount of calories.
two high concentrate bottles; one on the bike down tube to start and one in special needs…aero bottle for water only…drink from the calorie bottle on schedule…150 cals every 20 mins for me…and use the aero bottle for water only, refilling it at the aid stations on the fly from hand off water bottles…replace pre-mixed high calorie bottle at special needs…it is a long ride and you will want lots more pure water than calorie liquid…keeps your aero bottle for water and easy refilling and your calories separate, easily managed in two bottles and trackable to make sure your calorie consumption is right
At IMLP I stuffed 6 hours (1/2 hour more than I thought I would need) of InfinIT into a large water bottle. That was 1,800 calories, and just took water at the handoffs into the aero-bottle. It takes a bit of patience to get it to disolve, but it will. I order InfinIT with a flavor of “4” to use normally on the bike, and a flavor of “1” for the super bottles - otherwise it tastes like your chewing on a lemon!!! I’m going to up my on-bike calories from 300/hr to 350/hr this year and I think even that will fit in 1 super-concentrate bottle.
… just to add to what Darcy and others said… order the flavor on the weak side and if there is not enough taste for you, then you can always add some of those flavor crystals for water. Thats what i do. I have 3 bottles of Infinit loaded up on my bike to start and grab a couple more at special needs. I think that mixing on the fly would be too messy. It would drive me nuts to have sticky hands and arms from spilling.
Thanks everyone, great advice. I will have to try both ways on training rides to see how it works out for me.
Helopilot,
You mentioned starting with three bottles and dropping them as you go, do you take on any water throughout the race or are you just drinking the Infinit?
Thanks for all of the help everyone.
Never used Infinit but this is what I do with Carbo-Pro and Gatorade and 2 bottle cages.
I mix 4 bottles the night before the race, each with 1/4 of the total calories I’m planning for the ride. I put 2 on the bike and 2 in the SN bag. I start working on the 1st bottle at the beginning of the ride (some people recommend water only until your stomach has settled but this works for me) at the 10 mile mark I chug water and by mile 20 I’ve finished the 1st bottle of Carbo Pro and can rack a bottle of water. I keep working the water/Gatorade mix until the bike SN bag pickup and then start the process over. If I’m feeling really good and want some extra calories I pickup gels along they way.
Carbo Pro and Gatorade taste fine to me warm so this isn’t a problem. I train with it in Florida so I’m used to it.
I do this a lot during training by putting 2 more bottle behind the seat and I’ve gotten it down through lots of practice. Work great for me.
I put three on my bike and three with just powder in special needs at IM Fla. I did not want them to leak all over the place. The problem with that was there was no water at special needs. So, I guess I am saying make sure they don’t leak in your bag BUT have them filled(maybe frozen the night before) and ready to go. Can’t beat Infinit!!!
Kiri has it right. Bottle of concentrate and water only in the aero bottle. My mix is at flavor level 2, so the taste isn’t too strong.
clm
I’ve been doing almsot the same thing for my last 10 IMs. Only difference is I use Carbo Pro with Cytomax added for flavor and I carry both bottles of concentrate with me. Those special need stations can be a real zoo sometimes. I like to just cruise by and avoid all the congestion.
I just make sure I finish one of the infinit bottles every hour. If I am thirsty or finish the bottle early I drink water from the aid stations. But only straight water. This keeps my calories, salt per hour etc. right on track. I use to get cramps or feel nausea before doing it this way. No problems since on 2 IM’s and 2 half IM’s. I’ll be doing IMAZ again this year as well. I thought about trying the concentrated water bottle way, but the aerobottle always seems to rattle and drive me nuts. I don’t freeze the bottles. That seems to make them leak. I am use to drinking it hot from my training rides. If I need to cool off, I just grab one of the water bottles at the aid station and dump in over my head. I really haven’t had a problem at the special needs. I’m a mop’er and even if it took a couple minutes, it won’t matter for me. If I was going for a kona slot or a pro then I would probably do the aerobottle thing. But if it’s your first IM, I’d just stick with what works in training.
Let me warn you that mixing on the fly can be a real pain (and sometimes futile) in very windy conditions.
Crystal light has started selling single 16oz serving mixes in little “tubes” - the call them “on the go” or something like that. I’ve never understood why sports drink manufacturers don’t do the same.
That’s another great point. I tried the baggy thing a couple of times. Once while pacing a guy for the Angeles Crest 100 miler(so I wasn’t even on a bike). Both times I had a black shirt on and when I got done, I looked like I had just got done transporting cocaine across the border. It was all over me.
The crystal light packaging idea would be awesome.
Thanks everyone. I might have to try toning down the flavor and mixing a concentrate with my next batch of Infinit. I made one a little too strong the other day and I could tell that the flavor would be a bit over the top in a concentrated form. Thanks for all of the great advice.
Sport drink manufacturer’s can have it. The idea is free - my contribution to the sport. :wink:
What is the max concentration of InfiniT that one can make (as a gel)? I’m considering making up some stuff to carry in those gu bottles to dilute in my aerobottle, rather than the powder thing.
