Interstitial pectoral chest pain?
For the past 3-4 days I’ve had an odd muscle pain directly beneath my left pectoral muscle, slightly above my obliques. It’s happened only during runs, independent of the intensity of the run. I’d rate the pain at about a 5-6, so a bit more than uncomfortable but not debilitating. During breathing when I expand my chest, it hurts more, and then less when I exhale.
I’ve swam and biked a few times with no discomfort, including a few fairly hard intervals on the bike and drills in the pool. The pain doesn’t seem to be associated with my heartrate (ie it’s not more severe with a higher heartrate).
I’ve haven’t done anything differently lately. I’ve not been injured. The only thing that has changed slightly is I lifted weights the end of last week and did bench presses instead of my freeweight flies. I generally lift twice a week.
I can’t figure it out, but I don’t think it’s severe enough to warrant a trip to the doctor.
Any ideas?
Well, for starters, I’m guessing it’s intercostal pain, not interstitial.
Secondly, yep, it’s probably an intercostal muscle injury. It could be an costro-chondral injury, but, it sounds more muscular to me. Better hope for the muscle injury, it heals more quickly.
Could be intercostal neuralgia. Between each rib there is a nerve that starts at the thoracic spine and runs to the chest area. If this nerve is “pinched” or irritated it can radiate pain as you have described. Quite often it involves a joint problem with the rib and the thoracic vertebra that often responds well to chiropractic treatment.
As a chiro, I’ve treated this condition numerous times as well as had suffered with it a couple of times.
Guys, thanks for the rapid responses.
Titan, I think your right about my vocab. Intercostal is what I meant (and what I thought interstitial meant … dumb liberal arts grads!). My wife explained your post to me as if I was a German Shepherd (she’s a veterinarian).
Cerveloguy, any recommendations on selft-treatments? At this point, I wouldn’t rate it bad enough for a trip to the doctor (and a chiropractor would be out of pocket for me, unfortunately).
I’m going to skip running and upper body lifting for the next week or so.
If resting it for a week doesn’t cure it, you probably need a rib-resection (fancy term for removal of a rib).
God did the first one, I believe. The side-effects (where do you think the term, “side effects” came from?) are curvy beings that make you want to do things that you’d never do on your own…such as, wear underwear, paint walls any color but off-white, and button the top button on your shirt before putting a noose around your neck. So, be careful about going this route.
I hope the rest does the trick.
Once the pain has subsided I would seriously recomend staying away from bench press. Try as a more core related exercise doing chest press or flys with only your upper back or shoulders resting on a swiss ball. The effect should be 2 fold.
  1. Initially the amount of weight that you remove will be reduced, quite possibly dramatically as the limiting factor will be how well you can stabilise your spine. ie all the small stabiliser muscles of the torso will have to be developed before you create a stable base off which you can move heavier weights. At the moment the bench is providing that stable base not your core.
  2. A better way to improve triathlon performance. Bench pressing has almost zero relevance to anything in triathlon. I would even try going uni-lateral in a chest movement eg swiss ball chest press with 2 dumbell but doing 1 arm at a time. (That will give you a lesson in core stability!)
I hope it clears up soon.
Oh, sure, DA. Go ahead and give really good advice. See if I care.
Actually, as I have aged, I quit doing bench press because it makes my shoulders pop in some disquieting ways. I actually sustained a costal-chondral injury associated with bench pressing large weights over 25 years ago. The muscles from bench pressing looked nice, but, it wasn’t good for much other than, well, bench pressing. I’m a stability ball lifter for the most part now. And it sure seems to do some good things. The only free weights I do now are straight-legged dead-lifts. Not heavy, mind you, and sets of 15-20 reps. This really keeps my lower back from hurting.
OTOH, there is nothing wrong with a little extra muscle for us non-pros, non-elites to carry around, so I can’t say not to do things like the bench press at all.
