I am a 5 hour rider and use xentis wheels, a Hed Jet disc for very flat courses and Hed Ardennes for hilly courses. I switch between a setup with Profile carbon X bars and one with road bars (for hilly courses). I use an old 9 speed octalink setup, both for STI shifters and bar end shifters.
I tried to look into the tunnel tests, but they are difficult to understand as I cant translate “amount of drag” into “seconds”. Considering only frame aerodynamics, and a base time (with the aluminium lucero) of 4:55 in Florida, how much time would I gain with each of the 3 choices?
And just for comparison purbose, lets add a Trek TTX, a Cervelo P4 and a Quintana Roo CD01.
So I will start with the guess (only from the looks)
Baseline - Aluminium QR Lucero - 5:00 at IM Florida
QR Lucero carbon: 4:59:00
Cervelo P2: 4:59:00
Canyon: 4:58:00
Trek TTX: 4:58:00
Cervelo P4: 4:57:00
QR CD01: 4:57:00
Lets only consider aerodynamics and not do the "position … " mantra, I think everybody is aware of that by now
I read what you wrote about excluding anything except wind tunnel data from the analysis, and I know you already know this but, the windtunnel data *exclusively *is only a part of the overall set of things that contribute to your bike split.
Also, people tend to compare wind tunnel results as though they were conducted with some kind of standard protocol. They are not. That makes comparison of them of little real value.
Sorry Tom, as much as I appeciate your articles, which frame did you suggest I should buy
Three frames, I have no idea which is fastest, about equal price, and the “coolness” factor for me is about equal. So could you just give me a guess? I promise, I won’t hold you accountable, if my next ironman time is actually slowre than before
I want a new frame, I want to reuse all other components (wheels, bars, groupset), I want my old position and I want to spend less than 2000 EUR (including the setup). Possible with all 3 frames for sure.
But reconsidering, the answer is given. If one of the most knowledgable posters here on ST gives a “consulting type answer” (correct but not really supporting the decision process), maybe there is no correct answer.
So my current working assumption is: Go for lowest total cost (frameset + wrenching).
you’re not listening… the fastest frame aerodynamically may not be the fastest frame for you.
By your criteria, the QR .01 is the frame you should buy. If you need someone to make the decision for you and make you feel good… I just did. Go for it!
But, if you’re really serious, you know that the biggest component of drag is your body, and you know your body produces this drag as a byproduct of good or bad fit, ie. the frame that fits you best.
If you’re really REALLY serious, you’ll head to the gym or the grocery store and do what you can to slim/narrow your body down to reduce drag even further.
