I have heard that it’s a bit of a task to get the cables routed through the frame on the P3. Any tips from those of you that have done it before I attempt it?
Also, what do you folks use for cables? I’d like to use the same cables that came with the Dura-Ace kit but can’t seem to find Shimano cables—without the housing.
Thanks for any feedback!
Rob
feed it thru,tilt the front end up high and work that cable until it pops out the bottom. I have done it a couple of times. Not as difficult as it would seem to be…Good luck and be patient!
G
Push the cable thru as described. When it gets close use an old spoke to hook it and guide it out of the hole. Not that difficult but does require some patients.
