I have a road bike that has Profile Carbon Strykes on it and I’m thinking about replacing them with an integrated bar such as the Hed bar. Would there be any advantage with this, anyone have any thoughts on this?
Dan has some thoughts on this here:
http://www.slowtwitch.com/mainheadings/techctr/bikefit.html#Anchor-MUST-11481
Look under the section titled “WHY MUST SEAT ANGLES MATCH FRONT END CONFIGS?”
It can work well but my suggestion is to go to a smaller size than you would use on your tri bike. For the same reason you want a shorter clip-on on your road bike. This way you won’t be stretched out. A friend of mine put a smaller size Vision Tech on his TCR and it works fine.
