Intalling bar end shifters.. someone please help me
I swapped out my S-bends with some ski tip extensions, wanted to learn to do it myself. Re-did the cables (almost successful, 1 out of 2 started to fray a bit, how the heck to you avoid that while putting it through the protective housing?) .
My LEFT side shifter/front derailer is good to go, but my RIGHT/rear derailer isn’t working right. I carefully tried to put all the pieces of the shifter back together; there’s a tiny black toothed spacer-like ring in there that I must not have lined up right. I have no “snap” or click like it should to shift the gears. I have tried turning the ‘friction’ mode screw thing also. Anyone know of a diagram showing how to line it all up. I am 90% sure it’s lined up, but I’m missing something. Thanks a ton.
If it’s Shimano, the first piece that goes on after you’ve installed the main housing into the bar ends is a round, silver plastic piece. This piece has a little raised square in it and the square has one side that has a notch. That notch has to be correctly oriented or the whole thing messes up. I believe you want it to be pointing down, but I haven’t put one back together in a while and I could be wrong about that.
You should be able to download manuals from the Shimano website that will be very helpful.
To your other question, if you’re going to be doing a lot of your own work, be sure to invest in a good set of cable cutters that will make a clean cut. That’ll discourage fraying. Once a cable starts fraying, the only thing you can do is go well up past where the fraying seems to have stopped and make a new cut (hoping and praying that you’ll still have enough cable left to reach the derailleur).
I keep a large paper clip in my tool kit that I straighten out and stick into the ends of my cable housings to make sure they’re good and open before I attempt to run a cable into them. Sometimes cutting cable housing crimps either the outer steel wire or the inner plastic sleeve on the housing which makes it tough to get the cable in and restricts free movement when you do get it in. Using the paper clip to ream it out a little seems to help.
Good luck.
(BTW … I’m not a bike mechanic and I did NOT stay at a Holiday Inn Express last night.)
Cables are a dime a dozen. Never put a used cable back in, just replace it…poof…no fraying!! New cables have a welded end to prevent it from fraying until you cut it to length after it is installed.
Finally fixed it, thanks, was a matter of lining everything up like I already knew, just had to try about 20 different ways.
